FINE! I'll beef up that rod if it'll make you guys happy...![]()
Any slop in the pivots will allow grime in. Hell, just being under a truck in use will get grime in it. Driving it around will vibrate the handle and wear out the joint. Pivoting directly on the shoulder of a tension bolt is exceptionally bad practice. They are not designed to do that and the dimension of the shoulder is not consistent or a common size. If you want/need to pivot directly on the shoulder of a bolt you need a "shoulder bolt" as that IS what they're designed to do.ntsqd - what you are saying is great for a machine lever that gets used all day every day. This is a t-case lever that gets used during 3 weekend wheeling trips a year. It can pivot on bolts for years and not be an issue especially if it's in a long "H" dealio.
Nick
I also don't like to have to re-do something that I've already built. Maybe others feel differently, but when I build something my intention is for it to work and function as designed and built for at least 10 years. Look at how Mr. T designed the pivot points of the OE linkage. These trucks are highly vaunted for their good design and long service lives. You're going to deliberately build a part for it that reduces this reputation?
You really believe that they do all of that in a week?![]()
Well, over a year later and I am finally getting ready to install the H55/ToyBox/Split Tc combo into my 60 (pathetic, I know)
The problem I ran into was keeping the lever from being able to flop left/right. In a stock configuration it is the piece that goes down into the transfercase "receiver" that holds the lever. In my configuration I would be cutting that off to clear the 5th gear shift rail on the top of the 5th gear extension housing. Not an insurmountable problem but one that I chose to put off for now by going all custom.
You did not box in the internal shift fork?
