main engine wiring harness (2 Viewers)
So w
hat should I do? Kinda hit a bit of a brick wall
No replacement for doing a quick R&R on the glovebox to see how yours is laid out.
I'd think Mr. T would rather use a "1 harness for all" - but who knows?
Phone a friend? :meh:
-That or just take the 10mins to pull it & scout it now.
Can some one help!!
Yesterday I was driving and heaps of electrical things in the car stop working
RPM stopped, needle gages stopped, widows don't work , sub tank and central difflocks
Anyone got any clues?
Can some one help!!
Diff fuse blown?
Hey guys my green turbo light stop coming on the other day anyone know how to fix it?
Push it over a cliff once its fully engulfed in flames. Problem solved
When you get a replacement main engine harness in your hands - at the American Toyota price - it will be immediately apparent that it is one of the best OEM parts bargains in history. If a new harness is in reach financially, go for it, wrap it well with high temp insulation and never worry again. My 2 Cents. Mack
Your post compelled me to stash a new OEM harness for my '97 before NLA. It's like a steel sports Rolex. Even if I never have a real need for it, I can sell it for the same price or more.
Ordered!
Edit: It's on national backorder
CYKBC: It would be interesting to know where your harness was made. When you get it check the small white and red Toyota sticker with the part name/number and bar code on it (not the dealer sticker) to see where it was manufactured.
Reason I ask, last year I purchased a new main harness and it was Made in Vietnam so I compared it to another new (older stock) harness and it was Made in Japan.
Between the two harnesses, the Vietnam harness (purchased from a US Toyota Dealer in 2019) was not exactly the same (quality) as the Japan manufactured part, also purchased through a US Toyota dealer.
What I found was that the Made in Vietnam harness reflective/protective wrapping in the EGR pipe section was not wrapped as neatly or completely. The Japan part had the wrapping tucked in securely at both ends, no exposed wires. However the Vietnam harness wrapping was zip tied at both ends and was too short which left about 1/2" of the harness bundle wires on both ends unprotected.
Not a major defect by itself and it can be fixed easily by adding some extra protection. it just seems that the quality control and attention to detail was not equal between the two identical parts made in two different locations.
I'll post photos later.
More than happy to take a photo to suss this out when it's in my hands next week. I also noticed some other OEM parts I've ordered in the past that were not made in Japan (e.g. hoses). If my new harness is non-jpn, I'm returning it. Thanks for the heads-up, Kernal!
Well, you piqued my curiosity. I pulled out my new harness I purchased in February 2017 and am saving for later. Made in Japan, but has the heat shield tape held on with a zip tie and exposing some wiring. Either way, it will be better than what it replaces.
Frickin' hoarders......
I need to buy one......
Doubt they are going to let you return it.
Almost all dealerships say that electrical parts are not returnable.
  • Returned orders may incur a 20% restocking fee due to Toyota's return policy please contact us before returning.
  • Any order more than 90 days old is non returnable.
  • We are no longer be able to accept returns or cancellations for items with a cost below $10.00
  • Navigation upgrades / updates in the nature of CD's , disc , SD cards or Micro SD cards are non-returnable or refundable items.
  • Please be sure to call with your VIN number or have your Vin number on your order for verification.
  • If you have a problem with any item purchased, please contact us we are here to help and stand behind any item we sell.
  • A copy of the invoice will need to be included with the return.
  • Parts must be resalable and in the original packaging with Factory part number label intact.
  • Please do not use the Factory box that has the part# on it as the shipping box to put a label on. If the factory package is damaged or covered in shipping labels we will not be able to return or refund .
  • We cannot take back used parts.
  • We cannot take back installed or tried parts.
  • We do reserve the right to refuse and return any parts we find have been installed, are used or do not meet the above criteria.
  • The cost of shipping a return item is non refundable.
I'm probably just going to stash it anyways Vietnam or Japan or China or Mars. It's better than the 23 year old one I'm currently running.
And I remember now... it was the two PCV hoses that were made in China.
