manual says oil and filter change requires 6.8L (7.2Q) for a refill - what's the consensus when using the larger Mobil M1-209 filter? I'm thinking 7.2L (7.6Q)?
From my experience, 7 quarts is perfect fine.Put in 7 quarts and the stick reads full if I'm reading it correctly. What I don't understand is this:
The 100 owner's manual says with an OEM filter an oil and filter change will require 6.8 L (7.2 US quarts) for a refill.
But the Mobil 1 container says it holds 1 US quart (946 ML) of oil.
So according to Toyota a liter is less than a quart, while according to Mobil it is more than a quart?
Using Mobil's data, 7 quarts is equal to 6.62 liters, which according to Toyota is not enough even enough for an oil refill using the smaller OEM filter.
Using Toyota's data, 7 quarts is not enough for a refill using the smaller OEM filter.
Am I misreading oil dipstick, or are my calculations off somewhere?
