i'm looking to get all the links to all the appropriate posts for this and also see if i can get a parts list for this (including the obvious stuff since i'm a noob) as well as any more pictures. also any links for removing and reinstalling the axles or servicing the differentials. not in a hurry but would like to make sure i have it all together at some point.
any better links for this with a good walk through?
what about for removing and reinstalling the axles?
anyone got parts numbers for the axles or some of the other parts?
basically i would like to slowly start gathering the small parts and install the rear subharness etcetera in the event i get some time and money to do the mechanical part.
THANKS
LINKS:
PARTS (working on this):
front locking axle with locking differential (or just the front locking differential?)
rear locking axle with locking differential (or just the rear locking differential?)
rear passenger side locking axle with shorter splines (?) or machine down the non-locking axle
rear subharness with the locker wires (82163 - 60052)
ECU (of some kind?)
ABS and diff lock connectors
6 pin plugs currently use is for your ABS connector (?)
vacant 6 pin connector is use for subtank.
bulb holders and bulbs for locker lights in dash controls
THANKS
LINKS:
lx450 rear locker wiring
My head hurts, probably from smacking it againts my rig all day installing my new rear locker axel. I've found threads about fj80's needing rear locker wiring, but I've heard the lx450's have all the wiring ready to go. WHERE IS IT>>? I have the few feet of axel wiring on the axel locker...
forum.ih8mud.com
retro-fitting OEM lockers -Wiring Harness
Today I retro fit the main floor harness for the installation of OEM lockers. I am not sure if anyone else has done this. I know the 5 wire fix can be done but I wanted to replace the OEM harness. It was suprisingly painless. I still have the rear sill harness to do, that will come later in the...
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
ECU (of some kind?)
