LS Swap info. (2 Viewers)
Bay Area
I’ve been searching mud for an hour now and I haven’t found any info on LS swapping the 100 series. If any can point me in the right direction that would be great!
Thanks in advance.
Thanks in advance.
Normally the goal of LS swapping is cheap and reliable-ish power. Since the 2UZ is extremely reliable and not a total slouch on power I think the desire to LS swap is just very, very low.
For the relative trouble, I'd just turbo or supercharge a 2UZ. Figuring out the mods to do that is probably less work than properly integrating an LS. And a turbo'd 2UZ would be sweeeeeeeeet.
What's your goal?
What's your goal?
Plus nobody is doing much hardcore stuff with the 100 platform yet. More power to sit in traffic? Eh
What's your goal?
Thanks for your response. I just want more power. Our motors in our truck just doesn’t have enough power. I honestly don’t want to turbo or supercharge our high compression motors as it’ll cause even more problems. I think buying and installing a supercharger will cost just as much as a swap (maybe I’m wrong). I honestly need more info.
Someone on the Facebook forum posted this photo and said the thread was on mud. I have yet to find it.
Have you looked into the Doug Thorley headers and an unrestricted exhaust? @RobRed showed some serious gains on his TLCfaq site from just an exhaust if I recall correctly. If you can deal with the louder exhaust note, there's a significant power gain available for relatively little effort.
If you need even more, I would chase after a turbo or supercharged approach. "Good" engine swaps are a big ordeal unless somebody has already created a complete kit to do the swap. All the trouble to figure out mounting to frame, mounting to trans, AC compressor/lines, steering lines, exhaust, etc.... could just go towards mounting a turbo and the associated intake/exhaust plumbing. The 2UZ is an under-stressed and extremely reliable motor which had a factory supercharger add-on. It can handle a little forced induction. 5 psi would be a blast in a 2UZ.
Also worth noting the FI or engine swap route negates the largest draw towards the 100 - reliability. Not saying it's not worth chasing, but that's why you'll find such little info on it.
Might as well just go full monty and tackle the SAS while you're at it, too...
Thanks in advance.
9.6:1 is high compression?? News to me.
