Where these found on ‘62 Model?
I just looked and don’t have any.
@KY Longhunter - My understanding is that '62s didn't have anything like this. They started with the 4" lights in '64.
Yes. The original used as a pattern has wires out the top, and a small drain hole at the bottom.
Either way, it's going to leak.
Wanted to touch bases on this. Now that I've had the tub back on the frame for a few weeks, I've observed 2 things.Heat. The thermoplastic beads become soft and moldable at 140°F. Direct sun on black painted surface on an 80°F day softened the plastic, and in spots where it was a little thinner, it sagged from gravity. I'm not sure that having the tub on to shade them would have prevented this, but I suspect so.
Once I get the body back on the frame, I will probably pull them off (both sides did it), warm them a bit and reshape. Then we will see how they hold up in normal conditions.
I live in soggy Washington State where it is cold and rainy already.
It would certainly seem that nylon via 3D printing would be a really good option. As long as the material was either black, or able to be painted black. Does paint stick to nylon?The 3D scanning wouldn't be an issue. And they could be printed in Nylon with a melting point of 428 C. I would say the printing cost would be around $60 each with an initial scan price of around $200-$300.
