Anyone have pics of a fully bedlinered 60-series?
My son bought his 62 bed linered and is having hell getting it removed. I would hate it on mine but others appreciate it. Different strokes...
I'll pass the tip along. ThanksPurple strip discs. @Roark Supply sells them and is a vendor here. I've used them many times with good results.
The black on my donor rig had liner (IIRC AL's Liner) and 10 discs and 5 hours later I was down to OEM primer and bare metal and no warping. 36 grit on a 4.5" will make short work of it as well but be prepared for 2-4 coats of high build polyester and blocks sanding for awhile... Yep done that too.
Works case --- aircraft stripper and a long weekend.
J
I bought a parts truck that was lined up to the door handles. I believe it had been covered for about 8-10 years. The body had rusted out pretty badly from behind the liner in all of the usual areas. The liner did a good job hiding that but the truck was structurally compromised.
Could very well be! My assumption was they started with a truck that was already beginning to rust and did nothing on the back side to encapsulate.
