Installed a Liland Model 1918AA in my 1997 LC last weekend.
$195 plus $11 shipping from Rock Auto.
Install went well. No plastic parts to break down. I had a cracked tank on the original.
The design eliminates the side brackets (not the mounts). It was 3/16 less on width so I had to use shim washers to align the lower mounts, but that is better than being slightly too wide.
The fan shroud does not fit tight against the radiator (1/4 gap at the top), but I modified the shroud tabs to make it fit better. I recommend using the bolts left over from the bracket instead of the normal shroud bolts since the are shorter can can't touch the tank.
I have more photos of the fittings if anyone is interested.
I have only done normal driving in 90 degrees outside temp so far and coolant temp is normal.
