My entertainment for the weekend. OME heavies going under my 60. Just wanted to share with some folks who get it.
Haha, yes I do, but the damned thing is about about to be too short to lift the tires off the ground.I hope you have a jack. These trucks are heavy.
Yeah I had to go buy a new jack and some new stands to install my lift. And I barely made it happen.I couldn't manage it without a hi-lift jack.
You've got to lift from the frame, not the axles
I'll be picking up a long reach floor jack after I absorb the cost of the lift. My regular floor jack just wont hold any longer. Got my eye on one of these as well.I couldn't manage it without a hi-lift jack.
My 6 ton jack stands are halfway extended just to get the stock suspension and tires off the ground, I hope they are tall enough once everything is put back together.Yeah I had to go buy a new jack and some new stands to install my lift. And I barely made it happen.
I picked up a nice jack and set of stands from NAPA. Carlisle brand. I think the floor jack is a 3.5 ton and the stands are 6 ton. Not cheap to be honest, but it’s way cheaper than a hospital bill or a casket. After seeing cars fall and hearing a story of a dad getting crushed in front of his 3 year old daughter I have to insist on investing in a SOLID jacking system for doing work on these trucks. I also think long and hard about the physics of what I’m doing. If something falls where is gravity most likely to take it? And how can I make sure that DOES NOT HAPPEN?My 6 ton jack stands are halfway extended just to get the stock suspension and tires off the ground, I hope they are tall enough once everything is put back together.
I had to get onto my buddy for putting his Miata on 4 stands and removing all the wheels. He was using harbor freight stands... if one of those stands slips or fails, there’s really no telling where gravity is going to take that thing. I always want to have two wheels on the ground unless I have a proper multi thousand dollar lift to keep things stable. However. I’ve seen videos of trucks falling off of those things while mechanics are beneath them pulling transmissions. As soon as the weight of the trans was taken out of the equation the balance went off and the truck flipped off the stand with two people under it holding onto a transmission..... scary s***...Absolutely. I had a nice 6-ton floor jack but had to borrow jack stands from a buddy when doing my lift. I had 3 ton stands but felt the overkill of the 6 ton would put me more at ease when working under the truck. My floor jack barely got the truck up in the air enough to get the suspension completely unloaded. Was a sketchy endeavor even with the borrowed stands but I was glad to have them. Recently purchased a pair of the 6-ton dual-lock variety stands for myself. Like @cps432 I won't play games when it comes to lifting or working under my truck regardless of the cost. Wheels under the truck at all times and multiple jack stands per side/end holding it up.
Take a wheel and tire off and put it under the truck at the rocker, and if you have some short 4x4 blocks lying around use them to get the wheel up even higher, this as a safety catch ...just in case.
What size?Got my tires in the mail and mounted up this week. They look huge in the back of the Rav-4.
33x10.5 -15What size?
Heck yeah!! Feels good, hu? How’s it riding now?Not the best picture. I'll get a better one when its outside later in the week.
