Liftgate Latch Adjustment
Discussion in '40- & 55-Series Tech' started by Don in Va, Feb 4, 2004.
  1. Don in Va
    Don in Va
    31
    Dec 8, 2003
    I tried doing a search with no luck....
    When opening my liftgate, the latch on the passengers side hangs up and is difficult to open. Is this difficult to adjust?
    Thanks again guys...
    Don
  2. Landpimp
    Landpimp GOLD Star
    15,929
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    what kinda a Cruiser? 40, 55, 60 or ?
  3. Don in Va
    Don in Va
    31
    Dec 8, 2003
    sorry about that....its a 78' fj40 with an earlier hardtop.
    Not a bad set up...just wish the latch didn't stick. The pin pulls in to release, just not enough. :(
  4. Vortec62
    Vortec62
    55
    Dec 18, 2003
    Mine did that 'cause the tub was tweaked. I stacked washers between the hard top and the tub on one side to try to square the hatch opening up. It seemed to help a little.
  5. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    Open up the access panel in the back. You have a kind of closehanger wire kindof thing on each side. Each side has two overlapping pieces, which are bound by nut/bolt apparati. You loosen the nuts, adjust the wires to lengthen/shorten, and tighten up again. It is a trial and error sort of thing, but you'll get it.
  6. Don in Va
    Don in Va
    31
    Dec 8, 2003
    Thanks guys....
    I will be giving that a try. :)
