led light bar on top tabs of arb bumper
CO
Just like the title says. I want to put a led light bar on the top tabs (hood height) of my arb bumper. I searched with no luck.
Who's done it? What size of bar? Pattern? Brand? Etc. Any night shots? How do you like it?
Thanks.
And here's one example I found but with no details.
I want to put it in my lower tabs of my 80 series ARB .. but seems it's not really common ... I wanna see if someone already did ..
I am trying to get my brother to get a light bar on the main portion of his Tundra ARB. Should be able to get one that'll bolt to the bar there.
Use something like this...all over eBay or fab them yourself.
Got a link? I may order a few dozen if the price and quality is right.
I bought and modified a Rigid Mount and mounted mine on the lower mounts of my ARB on my 80. You could also use a piece of flat stock bolted to the tabs and then mount the bar to those.
If I had it to do again I would probably just use the flat stock and bolt it to that using the mounts that the bar came with.
The picture in the OP looks like it may actually be mounted to the core support or grill.
some have adjustable mounts.
I just got a 60w single row LED bar with a flood/spot pattern. the mounts are totally adjustable. I think the brand is Towtron (sp.?) it's a cheapo from ebay, but throws out a TON of light. I just got back from several days in WY. real dark out there...unless I'm leading the caravan. ;-)
here's a pic of it installed...
Did it line up with the ARB light tabs?
sure did.
the mounts, although not as 'rigid' as say...the Rigid, Baja Desgins, etc, (hah, hah). they are indeed fully adjustable for the width of the light bar. the tabs are 16" apart and that's the 20" bar, you can slide the mounts to any spot and tighten it down. Here's a link to something similar, and you'll see the mounting setup.
http://www.ebay.com/itm/20INCH-60w-...Parts_Accessories&hash=item4610687c41&vxp=mtr
yep...that's the setup!
It seems to be working well for me so far. I'm totally sold on LEDs now. I'm quite happy with these ebay specials, but knowing about rigid and Baja designs, I may go down that road someday. I'm AMAZED at the light these suckers put out. (heh heh, I said "put out")
