love2fly
Flying the Mountains of the NW
One of the last Items to be added to my LWB before paint is a removable rear bumper. Removable as I did not want a bolt on bumper just one that can be installed for around town and looks good, and when hooking up my off road trailer it comes off and then the trailer is hitched up. Who needs a bumper then.
I wanted it stout enough to were a it would take on small bumps and smacks to help protect the very light tail light frame metal section and some of the lower tail gate area. Of course any crash 10 MPH and above can be devastating, and can come from a VW or a Mack truck. Hopefully that wont be the case.
So with a length of 3" X 1" X 1/2" X 71" .120 rectangular tubing I built this removable bumper for under $27 not including the three welding rods used and three hours of time..
A glance you would think that this would not hold up to a child's Red Radio Flyer Wagon impact but I assure you it will take a lot more abuse from the top/side/ bottom and direct than you think. The only thing holding into place is the receiver when pined. The two 2" receiver inner bumper tubes welded on each inside butt up to the rear frame of the 45 (no bolts) and with two tabs (the main elements in keeping it stable) welded below both to stabilize it from moving (at all). Plastic caps are installed on ends of the tubing witched helped on the 2" tubing that was butted up to the frame from making metal to metal contact.
One can make the bumper bigger using the same manner.
Lean, clean, and simple, it's better than nothing.
