Wilson,
I have been very interested in the LII shackle sliders; so much so that I purchased a set last year, but not having any welding/fab skills, I have done nothing with them, but communicate with a few fab shops in Northern California in hopes of having these built into a nice slider (shackle) forward set up on the front of my 4Runner or Hiluxes like your old first gen runner had with shackles forward. The problem is that at least four fabricators (three of whom have been in Nor Cal for a very long time and have great reps) seem not as keen on the slider idea. I heard the same critcisms about dirt incompatibility, delrin wear, noise, and then I have also heard that once the slider boxes get banged hard on the rocks, and they get deformed even slightly, the springs will bind and not slide correctly.
My counter to such criticism was that the builder should mount the boxes in a away where they have protection around them (possibly with a boxed in skid plate that covers the slider boxes, does not interfere with the sliding movement, and which can be unbolted to remove the leaf springs).
I think running the boxes up front as an integrated part of a custom plate bumper would be bad ass. I am not trying to get the hackneyed shackle forward vs. reverse shackle debate started, but I am very drawn to what you have done with your rigs in the past.
I posted the following on Marlin's board, thinking that I spied your old truck in some pics there in 2009, but I didn't:
Juds One Ton Single Cab
And these are the posts that I referenced:
Pirate4x4.Com Bulletin Board - View Single Post - Tricks to keeping it low as possible?
Forward shackles and flipped springs - Pirate4x4.Com Bulletin Board
You may get a kick out of the fact that I was very interested and actually inspired by your shackle forward set up a few years ago, but unfortunately, I never did anything to get more info straight from the horse's mouth.
Do you have pics of what you are working on with Timmay's slider boxes?
If so post up please. Thanks also for your posts.
BTW, I have also heard that with a slider box forward (where the front spring's fixed end is located rearward at the fire wall), one will start bending leaf springs very easily, but my thoughts are that bending springs in such a way would really happen much more easily in the case of forward mounted shackles jamming into rocks and forcing the spring to krinkle up. However, with a slider box up front, the springs would be relatively protected, and bending would only occur if enough force was applied to the front axle or tires, and the vehicle could not climb over the obstacle that was causing sever rearward force against its leaf springs. Desert racing and this set up probably would not work, especially with the front axle having to push forward as it compresses on landings and encounters bumps or woops, but you know what? I doubt that I will ever be in that scene beyond the spectators' realm. ***** Sorry, I know this is the hardcore section.***** But, I want something that rolls smooth enough on the roads and highways to the trails, and a trail rig that deals with the mononotonously slow crawling that I still really enjoy. I can say that if I got the front axle lodged in a spot where the rear was pushing the vehicle forward, but obstacle allowed no possibility for the front axle to move upward and over, I'd probably pull back in reverse (if possible) and pick a different line.
Also, I can see another "pro" in that one could easily run a traction bar from the center section of the truck, and it would articulate in a similar arc with the drive line and leaf springs (just like a rear suspension). I'd love not having to worry about a long slip drive line, wierd u-joint and pinion angles, like you can get with shackles in the rearward position. Also, I'd like not to have to worry about the tires stuffing rearward into the firewall or trimming back that way either.
I am very interest to see and hear more about what you are doing, Wilson. If you know a great fabricator who is actually interested in building such a set up, I am all ears. It seems beyond stupid to pay someone a decent amount of money to build a front suspension that he conceptually disagrees with, you know?
