LC 2000 INNER TIE RODS
Baton rouge, LA
What's up guys
My 2000 LC's steering wheel is shaking badly on potholes, even the ESP started to react and break without my control. I did the 3-9 and 12-6 inspections it seems that the inner tie rods are loose on both sides (6-12 is fine) and there is an oil leaking from the driver-side boot. My question is which brand should I use for inner tie rods? can you please share links? I don't know which products or shops are reliable. also, what can I do to stop the oil leak?
Cheers from Baton Rouge, LA
Thanks in advance for your time.
Most here are probably going to say OEM, I’ve had great luck with Sankei 555 for the couple years they’ve been in my 200. I would assume they make the same for 100s.
If there is a PS fluid leak from rack, might want to look into changing the whole thing which comes with inner tie rods.
I just did the whole rack as I had fluid leaking also. It's a pain to do.
Rack and Pinion - Toyota (44250-60050)​
OEM Toyota Rack and Pinion For 1998-2003 Toyota Land Cruiser
