- Joined
- Sep 4, 2020
- Threads
- 138
- Messages
- 2,054
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
- Thread starter
- #241
15B-T oil pump
I want to change the rear timing cover gasket as a precaution (there was at some stage an oil leak in the area, though I think it came from higher up the engine). I also want to check the splines on the crankshaft oil pump drive gear. So the rear cover has to come off. Scraping off the 30 year hardened paper gaskets is an ordeal, but eventually the thing comes up good. I'm replacing the oil pump piston (because I have one) and the old plug, which is rusted on the outside. Why this little plug comes in its own cardboard box, I cannot imagine.
The oil pump gears are almost like new (a few very light marks) so I'm keeping them original (even though I have a new set). Instead of petroleum jelly, I am using a bit of assembly lube to keep them lubricated before their first operation.
I had previously rebuilt the 3BII oil pump/rear timing cover which could have been used on the 15B-T. However, whilst being interchangeable, the 15B engines (and 14B-T) have a higher capacity oil pump, so I'm sticking with what came with the 15B-T.
With the 3BII front timing cover. This part does not have the aperture for the onboard PAS pump machined, so I will use this alongside the belt driven BJ60 pump.
Rear view.
EO
Rear view.
EO
