Land cruiser 80 / HDJ80 body left hand conversion (1 Viewer)
Barcelona, Spain
This question relates to the feasibility and effort to convert a right hand land cruiser 80 body to fit a left hand car. To avoid confusion, lets say you have a left hand land cruiser 80 and need to change the main body only. What would it take to adopt a right hand body? I guess the front panel where there steering gear and cables go through would need to be changed. How much cutting and welding would be involved and what is the degree of difficulty?
Many thanks
I've done a similar project recently - converted a RHD HDJ81 to LHD. It was VERY involved and more difficult than i originally anticipated.
Converting the body only would be a lot easier - you wont have to worry about the frame/axle modifications. If you can reuse the dash wiring harness from the LHD truck, that will make it even easier.
The main difficult thing you'd have to do is convert the firewall and the cowl. There are dozens of little mounting brackets on the inside of the firewall that you would need to cut/weld from the donor truck to RHD body for all the things under the dash to bolt up to. As far as the holes for the AC lines/wiring/steering shaft, what i did was cut those sections out from the donor truck and weld them into the RHD firewall. Finally, you'd have to relocate the the cabin air intake in the cowl from one side to the other. And relocate windshield wipers. There will also be a million other small things that you'd need to do, but the above would be the most difficult part. Looking back at it now, if i was crazy enough to do it again, I'd pull the engine and replace the entire firewall with the LHD one. This would be easier to do than modifying the RHD firewall.
Many thanks
Thanks. I can image a complete conversion is tough, very brave! So I have a LHD car and it will remain LHD. I just need to change the body (it has rust). At the moment there are no LHD bodies available but there are some RHD. I could reuse the firewall/front body section from my current LHD body. Would it then just be a matter of removing the firewall from the RHD and weld in the one from the LHD?
