Jumping 12V to B+ to Test Fuel Pump? (2 Viewers)
1994 80 Series, right hand drive, gas.
I am trying to see if the fuel pump is bad or if the fuel pump relay is bad. I see recommendations to Jump 12V to the #3 terminal in fuel pump relay to directly power the sensor (Emergency Troubleshooting Procedures - FAQ Item (Recommend Keeping Copy in Truck) - https://forum.ih8mud.com/threads/emergency-troubleshooting-procedures-faq-item-recommend-keeping-copy-in-truck.115816/) - what kind of wire should i use to do this? Do i just take a wire and hold it to the positive terminal on the battery and push it the other end into the #3 terminal?
For context, this puppy hasn’t run in 18 months or so. When I put it into the garage for storage, I had run most of the gas out of the tank and left ~.5 - 1 gallon in the tank. I put 1.5 gallons in today. Cranks, but won’t start. I was able to start it up by spraying starter fluid into the intake, so I know I’ve got spark and hopeful i have compression. Fuel pump doesn’t sound like it’s running and the fuel gauge shows completely dry. Also, the speedometer doesn’t (or didn’t work 18 months ago), but I don’t know if it’s related. Any advice is greatly appreciated!
You can bypass in the diagnostic connector with a basic jumper.
Recently shared by @jonheld:
By jumping FP-B+ in the diagnostic connector you have bypassed all fuel pump logic and the pump will run whenever the key is in the ON/RUN position. This is potentially dangerous as the pump will continue to run in the event of a collision.
I marked my diagnostic connector with a paint pen so I can easily jump the fuel pump as a limp home measure to get off trail.
Thanks for the reply! Just to be clear, like basic jumper cables? I’ve never done anything electrical with a car, so I’m fumbling my way through it.
I have a simple jumper wire, like 12 guage wire, with flat pins on the end that I made, but some guys even use a paperclip. Jumping the battery 12v + (+B) and Fuel Pump (Fp) pins in the diagnostic connector on the firewall forces the fuel pump to run on high, bypassing the fuel pump relay.
Here is what I made for this:
But you can literally use a paperclip (not plastic coated, of course).
Clarification request-- this is for the 93/94 OBD 1 vehicles? And it uses the 93/94 diagnostic port?
I guess I should go find the @jonheld post.
Mine is a 1994 US Delivery 80 Series with OBDI and this procedure works on mine.
This is only for OBD1. There are 2 different diagnostic connectors between the 91/92 FJ80 and the 93-early 95 FZJ80, but the concept is the same.
By jumping B+ to FP, you are providing +12 directly to the fuel pump when the key is in the ON/RUN position, bypassing all fuel pump logic.
91/92 FJ80
93-95 FZJ80
Thanks much Jon--
So is the electrical connection in doing this good enough to get you home, or is this something that should really only be used for testing purposes?
Thanks much Jon--
It will keep the fuel pump running as long as the key is in the ON position and the EFI relay remains closed.
In the event of a collision, rollover, etc., the fuel pump will continue to run even if the engine stalls. You need to be aware of the potential hazard if you decide to drive in this condition.
