- Thread starter
- #81
s*** work. Satisfying in the end always but s*** work just the same.
It’s going out behind the rear just behind the shackle.You exhaust out the rear, not behind the driver's rear tire?
That exhaust is art.
What's that dimple die metal about?
That’s a 4x4 Labs bumper. Drain holes.What's that dimple die metal about?
AhThat’s a 4x4 Labs bumper. Drain holes.
For the highly rusty spots you can use an aggressive applicator yes.What do you apply Quick-Glo with? Steel wool?
Punched out a few things.
Bled brakes. Bled clutch. Added rear driveshaft.
I’m about to start in on the interior. This is a total s*** job but it’s such a gamechanger when it’s finished
Still very thankful @dnp went through all the R&D to have these carpets made
Yeah. That first panel install was riddled with me doing things in the wrong order and getting ahead of myself. It took me more than an hour to figure it out.N,
1-Remove old panel
2-Remove upright supports
3- Install hinges to front of panel and door
4- Put thin backing plate behind panel
5- Install with supplied M6 hardware
J
