Brake fluid flush/ fill yesterday, when laying underneath the front I noticed on the passenger side there was a gap between the knuckle and bottom of the axle.
Put a 17mm on the nut and found that they were finger tight
Started tightening up and BAM, with little pressure the (2) forward studs broke, nut, washer, cone and stud remnant fell out.
Tightened up the (2) on the rear and made the 20mi trek home. Also noticed the steering wheel being slightly off center since I tightened those (2) remaining nuts.
Drivers side was tight and did not come loose.
I should probably replace all (8) of those studs, cones, washers and nuts...
