My vgt is controlled by a crude but effective spring. I originally tried a waste gate actuator(like the picture but not mine) opened by drive pressure but boost was limited to 15 psi because it opened too soon.
After reading, I just attached a hardware store spring to the collar lever. This holds it in "quick spool mode" until enough exhaust pressure(not drive pressure) builds and pushes the collar further open(into wide open position not surging?), against the spring.
So, light throttle- high turbine velocity
Heavy throttle- high turbine flow
I'll admit, I don't really know anything about turbo maps or surging, but I do know this turbo MOVES AIR. Compounds would probably produce better results, but at what cost? I gave 300 bucks for my sooted up VGT. Only downside I see is high drive PSI.
If I were smart enough I would have figured out the exhaust brake by now!
