You need to shift your EGT probe to before the turbo. Which fuel pump do you have? Some have boost compensators, some do not. If you have a sick boost compensator then you'll be way down on power.
I've run my engine at up to 750 deg C preturbo regularly for a long time with no issues. These engines are built to work hard all day, factory fitted oil spray, oil coolers etc.
What rpm do you think you have at 65mph?
A smaller wastegated turbo will give more boost, but I'm not convinced boost is the only issue you have right now.
dougal and company, thanks for the comments. you are right, that the 3.9 should not perform like a 5.9! the trucks are about the same weight empty, i do expect to have that same torquie power though.
egt to preturbo - that means removing the turbo? I guess i should just rebuild it then while I have it off, seems like the only thing not rebuilt on the motor. Preturbo is more accurate temp reading?
fuel pump - I have a inline low pressure mallory I added back near the tank, and the lift pump on the IP.
boost compensator? - is that the aneroid, altitude compensator? besides this on the back of the IP, there is nothing else.
Timing - is there a more accurate way to get the 13 deg BTDC on the IP? I take #1 line off, and turn the engine over, see the fuel rise in the delivery valve. i would guess this is accurate to within a few degrees only.
egt temps - wow - that is like 1700 deg F. It does feel like the engine is just getting into its game, getting power, getting boost, when I am having to back off of a 1050 to 1100 egt. would be great to let er bark to like 1300 or 1400 F, but I am obviously concerned about melting something down!
rpms - I have yet to truly calibrate this tach, I can only estimate from a idle and governed rpm. with the over drive on the rpm is running approx 1500 to 1700. I do think this will work great on the open flats, great gas mileage. but it does feel geared high, especially with the 33 tires on there.
a quick movie of the engine running after rebuilding the IP.
YouTube - 1988 fj62 landcruiser with isuzu diesel engine
...Some engines have an altitude compensator (FSM calls this an aneroid) which is a round device with no lines attached...
Hello, i've been driving around my 4bd1t powered fj40 for about a month now and finally got to putting in my front drive shaft. i have about 1 1/2" to 2 " between the front drive flange at the pumpkin and the oil pan. well its not enough because it hit, now i have a big dent in the pan.
I saw that 88tlc did some work to his pan. I was wondering how much room is in the right front corner of the sump. is the oil pump or pick up near there? 88tlc how much did you find a new (or used ) oil pan for? My 40 is now my daily driver so i was thinking about getting a used pan to modify.
any advice would help thanks?
The oil pump is quite a way back. On the turbo side of the motor you'll see a cover plate with two bolts just above the starter, that's the drive for the oil pump.
The front of the sump is pretty much clear for modification, but you need to pull it off to check anyway.
I'll have mine apart shortly to change the thrust bearings (forgot to order them last rebuild).
.Astr, is that an oil return on the sump.. where from.?
That little tube connection on the right rear corner of the oil pan is a return from the air/oil separator. A vent pipe from the valve cover goes to a cylindrical (4" x 2" dia.) air/oil separator that, I assume, has some sort of internal baffles. There are two tubes coming from the bottom of the separator - one vents to the atmosphere and the other goes to the oil return on the pan.
