I talked to Dieseltim and he told me the kits are $750 and includes the machine work needed to modify the Isuzu 5speed bellhousing. If you chose to have someone else modify your bellhousing then they are knocking $100 off the kit for the machine work. The kit includes the pilot bearing, the clutch disk and the adapter plate for $650.And the price is?
The plate is 6065 t651 Aircraft quality alum. and all of the bolts are 1/2 coarse threaded bolts. I went with the 1/2" thick so that the input shaft and the pilot bearing have the proper ingaugement, if you use anything thicker you will not be into the pilot bearing far enough. I decided that 1/2 was thicker than the bell housing, so the bellhousing would most likely fail before the adapter plate.
For those interested here is a few more pics.
Dieseltim
No I don't, but if I go this route then I could try to find the Dodge trans to save some work.You do have to have an NV4500, it can be Dodge or Gm but it will have to have an input shaft for a Dodge because they are about 1" longer than the Gm input shaft. If you have a Gm NV4500 then all you have to do is change out the input and you can use this adatper kit.Dieseltim
Now that my project is actually progressing, next up is the radiator. It's a 4BD2T going into a '72 FJ55. I've got the stock 55 rad and the Isuzu rad (way too tall). Isuzudieselswapper says stock rads are fine regardless of application and I am always leary of all encompassing comments like that. I see a few have stuck with stock and a few have changed out. Since I'm gonna be running a/c there's a little more strain on the engine but not much.
This may be one of those good to do now if you have the extra cash but wait until later because other costs are piling up quick.
Driving test ! - I am still not happy with the power. I can not hold the overdrive when going up a hill, and have to go to third gear, and will go about 55mph. it is at altitude about 6000 ft, perhaps a 6% grade. I had HOPED that the 88tlc would cruise up the hill like my Dodge cummins. but I do not have that kind of power, or torque. I would welcome any thoughts on this.
some data first
stock turbo, no waste gate - the turbo will obtain 10 psi boost, but I gotta have my foot in it! at cruise it is perhaps 4 to 5 psi. egt gage is post turbo.
injection pump, and injectors - stock, rebuilt. fuel turned up approx 6 %. Timing was checked at about 12 deg, but this seems to be a course measure per the manual.
700r4 with overdrive. I also have 33s on the rig now. 4.11 stock gears.
at cruise- 65 mph, egt are at 1000 F, boost about 4psi to 5 psi. there is a bit more power there, but the egt are high!
Up a hill - 4% to 6% grade. i have to shift down to third. it has plenty of power but the EGT can climb quickly . boost is 5-7 psi?
what is the EGT temps that this isuzu handle? the small oil jets that shoot into the cylinders, and cool the pistons, post turbo.
would a wastegate turbo give better power, early in the throttle?
