isuzu 4BD1T swap?!
I talked to Dave not too long ago about the whole bushing/pilot bearing thing. The photo should help to explain it. You need the bearing from the manual flywheel set-up, not the auto. My started as an auto and that bushing is too big. It should be #188 not 188A. I can't confirm this though because I still need to order mine to make sure it's the right one.
your right, my apologies for that. i remember now that i thought about replacing the pilot bearing because it was seized but didnt because it doesnt spin on the adapter. now i am wondering why he didnt make it for no bearing at all. hmmm. i can stop at the dealer and get a number if you need it.
The only reason I can think for the adaptor going into that bearing is to help with initially lining up the adapter to the flywheel. ??
If you could get me a part number and find out shipping to 93955, that would be outstanding.
We're getting closer everyday, almost to the point of nickel dime stuff like separator and routing of the turbo. Still trying to figure out best option for the intercooler. It doesn't look like we can get the stock to fit too well. I think with the auto trans the size of the bellhousing pushed the engine just far enough forward that we'll need to go a different route. We'll see here pretty soon. I need to update the build thread with the latest and greatest.
Okay,
I read through this entire thread; wow there is lots of info, and now I want to scrap the plans for the 2F in my 72 Fj55...
Some of my thoughts:
I really like the idea of a manual 5 speed in my project, but I am not a fan of the NV4500 b/c its a stiff shifting tranny with a few gaps between gears that I didnt care for. So, this leads me back down the h55f path.
The standard h55F that everyone puts behind F/2F/3F motors has the shortest input shaft length of the different versions of the tranny available. The B series has a longer input shaft with 21 splines, and the HZ version has a slightly shorter input than the B, but longer than the standard h55f, also with 21 splines...
Maybe one of these will give enough length to run the bellhousing plate like dieseltim did with the NV4500???
Anyone have the different lengths of these input shafts?
okay, search for some pics from the various sections on the board, and found thisI(shamelessly pirated)...
Might be doable with the HZ input(pictured with the 10 spline F/H series input, or the B series(pictured alone)
Interestingly, rick D says there is an isuzu clutch disc that fits the fine spline input of the HZ and B series input and is 300mm OD?
There seems to be two different manual transmissions that were used with the 4BD1/2T in the US. The MSA-5D was used with all of the 4BD1T's and the early 4BD2T's, until about 1996. In 1997 and 1998, the MXA-5D was used. One of the differences between the two transmissions was the input shaft. They were the same length and had the same diameter pilot bearing (17 mm), but the MSA input shaft had 24 splines and was 24.8 mm OD at the splines whereas the MXA input shaft had only 21 splines but was larger diameter of 27.7 mm. The shaft on the left is on an MSA-5d and the shaft on the right is on an MXA-5D.
Not just in the US.
I have an MSA-5P which was allegedly new in the early 90's, it has a different spline to the MSA-5G I am currently using which is substantially newer.
The clutch plates are all that is needed to fit either box up to the engine, I have both here which I can measure. This is a limited time offer, the engine will be going back in shortly. It's currently out so I can replace the thrust bearings which were forgotten about in the last two rebuilds.:whoops:
I dont have the dimensions on the HZ or B series 21 spline inputs, so I am hoping that someone will post up. I am thinking that a bellhousing plate that serves as the adapter to the bellhousing, as well as the front bearing retainer(also with the sleeve for the T/O bearing) for the H55F. obviously this will be possible with the longer B series shaft, and it would be great if the spline count/diameter worked so the clutch worked out...
There is a good local machine shop in North county SD, and I might try to find an engine and by an H55F to get this figured...
Is this FIRST HAND EXPERIENCE that you've had w/ the NV4500? I ask cuz that's the 1st I've ever heard of this "stiff shifting" & "gaps" between :confused: I've driven 2 different rigs w/ NV4500's for many years & couldn't imagine a smoother shifting tranny. I guess you're not concerned about having a low geared tranny for off road? :rolleyes: Is that Toy tranny geared in the 6:1 range, like the NV4500?
yeah hamma they're geared pretty low,,, 5.3 or somethin.
i have an H55 thats all disassembled right now, i will be replacing the R150 with it at some point but the R150 is doing great behind the diesel,,, smooth as silk and an awsome tight shift pattern. when i do it i will most likely have a custom bellhousing made to put the H55 on the isuzu using the isuzu flywheel and toyota everything else, pretty simple just money for the custom bellhousing.
Just wondering if anyone has a completed Isuzu FJ80 yet? This was my first choice a year ago when I started thinking about my conversion. I would still like to hear how it does in the 80.
Rusty
Yes, it was my experience in my own truck and another FJ40 of a friend. both were the rare early GM 6.34:1 verisons, and not the MUCH more common later GM and dodge 5.61:1 later versions...
I had mine rebuilt with new bearings and synchros, etc, ran the oil everyone recommended, etc, and still it shifted poorly, as did the one in my friends Fj40...
The low geared GM versions with the 6.34:1 first have a longer gap between second and third and fourth. I just didnt care for this. Consequently I am not interested in running an NV4500 until I have exhausted the options of the toyota 5 speed. Glad you liked the NV4500, but we are entiltled to our opinions...
whether its the 5:1 first of the toyota or the 5.6:1 of the 10 times more common later NV4500, its a wash when theres other ways to get low gearing, IE 4.7:1 toybox.
Rusty
I am in the middle of my swap:bounce:. I have some fears about the power of the 4bd and the weight of the 80. I will probably end up intercooling it and putting on a turbo with more boost. I about 3-4 months from the maiden voyage. I'll let you know.
I got the OME lift installed, fuel tank dropped and fuel pump removed, engine mounts cut off, and cut out the unleaded spring door in the the fuel filler neck. I am getting all this done as I wait for Isuzudieselswapper to get more adapters, it has been well over a month now.:meh:
just to add some fuel here... heh heh... the h55f is 4.84:1; not 5.1.
I have had three h55f trucks... V8J60, Cummins6A3.4t-60, BJ74. I've also had three NV4500 cruisers... V8FJ46, V8FJ60, 4BT80... and a '98 Dodge Cummins...
I have to say that, I felt, the NV4500 is a lil bit nicer. Second gear is lower, so you don't have to use first; and the spread between the gears seems more even. Also, the 5th gear is a nicer drop in noise and RPM. My favorite was actually the rare 6.34:1 i had in my V8FJ60... that sucker would crawl pretty darn well. Not as nice as the FJ46 with NV->Orion, but not bad.
But, they are both sweet transmissions. And you can actually pick up an H55f... whereas the NV4500 , two of us couldn't carry it (well, it was bolted to the Orion)
