- Thread starter
- #601
So the HJ60 rad is how different from the FJ60 rad?
Identical other than the top outlet and rad cap are on opposite sides. The FJ60 rad is the one you want its got the outlet on the correct side, I need to get mine swapped.
Out of curiosity why did you remove you headlights?
That intercooler looks like a sweet fit Jerms. I'm must confess I a tad jealous. That thing will perform well for you. Offsetting your fan will also help it pull better. I forget what is ideal, but your close to it. I really like that copper pipe work for heater lines. I think I'll have to borrow that from you as I'm going to be doing some of the same work in a month or so. Your intercooler/rad support looks very functional and will let you take it apart quite easy. I dropped by this sat, but you were not there so.... I went to Kms for an hour and half. My kids were at go bananas. I can't stand that place. Just wait till you have kids!
Sounds like that internal design is to maximize surfaces area for transfer. I'm pretty stoked for when you post up effeciency numbers. I expect they will be quite impressive. I hear ya for the running around. I'm in Aldergrove so I'm 20 min to either Abby or Langley, so mostly I get stuff from Alderauto or otter coop. Fortunately they both have some weird stuff, so I usually can make it work. I'm interested to see how you do your AC lines as I'd like to reroute mine sometime. Good work man. g
Sounds like a good tube and fin style intercooler. They are difficult to find as most are bar and plate. What is it out of and does it look like this inside? The tube and fin type flow much better to the radiator behind.
Do you have pics of the baffle you put in your intercooler? It's a great idea by the way. Evening out the flow can increase effeciency as well as net less pressure drop across the core... A real win win. g
