hi sarge,
thanks so much!!
i got your pm and will call but it may be a few days as i have to tend to my day job first.
plus, i want to check a few things before we talk:
1) my float level - my 32/36 has a plastic float, and i presume that per your drawing above, 51 should be 18mm as that's what the weber directions say should be the deflection. if it's not, how is the float level actually adjusted? by bending the tab?
2) my vacuum advance seems to work properly, but i think my dizzy also has a centrifugal advance, as when i disconnect the vacuum adv, the timing will still advance under acceleration. maybe it is advancing too far?!?! my dizzy does have an octane adjuster on the left side and per my book, it's supposed to change the timing slightly depending upon what octane gas it's running. i've tried to set it at zero. also, per my book, i may go ahead and pull the dizzy as it now seems really suspect and may be malfunctioning, which could be a large part of my back fire issues.
in trying to make it run right, and per a guy with redline telling me that my carb's too lean, i'm the one (or the dummy) whose been putting all those different jets in the carb, although i've not changed the emulsion tubes; those are original and both #F50. you're correct, the plugs are blackened and do have soot deposits on them.
talk soon and thanks again!!!
thanks so much!!
