I finally got my OEM tire carrier installed so I thought I'd post some pictures and try to post as many details as possible. The first thing I did was download a diagram of all the parts needed for the tire carrier so I could put together a parts list. I can only attach 5 images so some of these are imgur links.
Here's the part schematic I dug through to find the parts needed. I only used the parts I deemed necessary but some of them such as the caps for the hinges I left out to save money.
I came up with the following parts list out of this document:
I believe most of these links should work and the total for me came out to about $750 not including shipping.
Outside of impex, I also bought some hardware from my local home depot and ace hardware.
* Everbilt 36 in. x 1 in. x 1/8 in. Steel Angle 801457 - The Home Depot - https://www.homedepot.com/p/Everbilt-36-in-x-1-in-x-1-8-in-Steel-Angle-801457/204225879
* Nuts for M8 1.25 pitch coarse. I'd buy 10-20 nuts just to be safe.
* Threadlock blue: Don't want vibrations to undo anything. The OEM ones actually come with red but I wanted to be able to adjust if things acted funny
* 4 60 mm M8 1.25 pitch coarse bolts for the striker/latch mechanism.
* ABS Spacers: Amazon.com - https://www.amazon.com/dp/B0915F7K77
I'm no tradie but I I believe the angle iron will be sufficient across 6 bolts to keep the sheet metal from tearing and I cut them in a way to minimize the bends of the sheet metal. If the sheet metal tears, I will update this thread with egg on my face. The is no OEM solution for reinforcing the sheetmetal as I believe the D pillar reinforcement is only done at the factory. You can buy an oem reinforcement for the latch guard but it was pricey so I used angle iron there as well. You will have to remove the plastic trim for the bottom hinge to ensure a good fit. I intend to cut it right up to the hinge and reinstall it so it's less bald.
To get the latch to close correctly on my LX470, I had to angle the striker with two of those ABS spacers turning it towards the latch just a tiny amount. I believe I used 5mm all around plus 2.5 on the left side to get the angle right. I'm noodling how to get my light installed but it involves cutting into the tire carrier a bit. I might see if I can adjust the light fixture instead. I used the 60 mm bolts here to account for the spacers. Do your best to avoid hitting the key hole mechanism for the rear tailgate when aligning your striker/latch plate. I almost knicked mine. I covered up my keyhole but I never use it so I didn't mind.
I'm sure I missed some of the details but a lot of the work was coming up with the parts list so I hope that at least benefits someone here.
51930-89101 TOYOTA LOCK ASSY, SPARE new spare part | 1 pcs | JP¥4,680 US$30.42 | 0.374 kg | |
51905-60020 TOYOTA STOPPER SUB-ASSY, new spare part | 1 pcs | JP¥2,500 US$16.25 | 0.27 kg | |
51950-60030 TOYOTA CABLE ASSY, SPARE new spare part | 1 pcs | JP¥1,790 US$11.63 | 0.13 kg | |
51940-60010 TOYOTA STRIKER ASSY, SPARE new spare part | 1 pcs | JP¥990 US$6.43 | 0.1 kg | |
51933-60070 TOYOTA スペアホイ-ル ストツパ- new spare part | 1 pcs | JP¥730 US$4.74 | 0.084 kg | |
51907-60060 TOYOTA STOPPER S/A, SPARE new spare part | 1 pcs | JP¥810 US$5.26 | 0.079 kg | |
90119-08898 TOYOTA ワツシヤ-ボルト new spare part | 6 pcs | JP¥160 US$1.04 | 0.016 kg | |
90170-10030 TOYOTA ナツト new spare part | 1 pcs | JP¥90 US$0.58 | 0.01 kg | |
90159-80045 TOYOTA スクリユウ | 2 pcs | JP¥110 US$0.71 | 0.01 kg | |
90119-06615 TOYOTA ワツシヤ-ボルト new spare part | 2 pcs | JP¥140 US$0.91 | 0.009 kg | |
90469-09003 TOYOTA CLAMP new spare part | 2 pcs | JP¥130 US$0.84 | 0.005 kg | |
90959-01423 TOYOTA クランプ new spare part | 1 pcs | JP¥210 US$1.36 | 0.003 kg | |
90119-06614 HINO BOLT, W/WASHER new spare part | 3 pcs | JP¥255 US$1.66 | 0.01 kg | *-06877 |
51099-60020 TOYOTA PLATE SUB-ASSY, new spare part | 1 pcs | JP¥2,450 US$15.92 | 0.43 kg | |
90942-01103 TOYOTA HUB NUT (CLIP NUT) new spare part | 3 pcs | JP¥540 US$3.51 | 0.1 kg | |
90119-08769 TOYOTA ワツシヤ-ボルト new spare part | 5 pcs | JP¥90 US$0.58 | 0.019 kg | |
90159-80046 TOYOTA スクリユウ new spare part | 1 pcs | JP¥110 US$0.71 | 0.015 kg | |
51936-60070 TOYOTA CUSHION, SPARE WHEEL new spare part | 1 pcs | JP¥630 US$4.09 | 0.01 kg | |
51935-60060 TOYOTA CUSHION, SPARE WHEEL new spare part | 1 pcs | JP¥630 US$4.09 | 0.01 kg | |
51903-60120 TOYOTA スペアホイ-ル キヤリア new spare part | 1 pcs | JP¥93,200 US$605.75 | 16.5 kg |
