Install notes for Ironman bullbar on a 2008 LX (1 Viewer)
Is that the same case for the LC version that the winch will fit wo removal?
I’m not sure.
But the zxr is one of the smallest 12,000 lb winches so if any will fit, it’ll likely be that one.
I don’t know if I’ve already posted these photos somewhere but I’ve been asked for them a couple times via social media…so I’m going to post them in this thread.
(5 photo limit)
Hey all. I have ironman bumper and factory points are blocked by the bumpe mount.Any sugestion whst yo buy?
Just notch the iron man brackets and run whatever you want.
Like tbisaacs said, you can notch the mounting brackets for the ironman and run arb recovery points…images attached.
Hey All. How to wire the indicator /patking led lights. There are 4 wires from ironman bumper light. Its my last thing to do. Thanks. 2014 lx570
1 is ground
1 in turn signal
1 is drl
1 is parking
I used a scotch lock connector to t-into headlights etc
Are the colors of the wire mach colors on the headlamp wires? How to identify them?
No they won’t. You can find the wires on the headlights by looking at the connection going into bulbs. For DRLs you can use Any switched 12v source.
I have a set of tundra tow hooks on the way from a parts picker on eBay.
Do you have a picture of how these mounted? Did you still need to notch the iron man bullbar?
Lastly, what did you end up doing with your front facing camera?
I ended up not using them. They eat up like 4” front clearance because they hang so low. I notched the iron man mount and am running arb recovery points.
Camera is mounted in the slot just above winch fairlead. Yes I took a hole saw to my front plate 👹
your link doesnt work—but lots of smarter people than me who do harder recoveries than I have. I'm not here to change your mind either way.
Updated the link, thanks. Was just curious what your deciding factor was to move away from them. My use case is more moderate than hard-core. Level 3 (out of 5) trails max.
