you mean this one
https://forum.ih8mud.com/80-series-tech/584392-1995-fzj80-5-3-4l60e-np203-splitcase-swap-5.html
I've been thinking for this for a while and just decided to pull the 6.2 diesel/700R4/np 203 out of my 84 suburban. Then a AA to add a split case and in it goes..... hopeful start time will be Jan. 2013
Don't put in a 6.2...That's an anemic motor...
Oh really? That will be a badass setup![]()
It is a bad ass set-up. 80s were made to have LS motors in them. It's a perfect fit and the power makes these trucks drive like they should - WITH AUTHORITY.
Not compared to a nutless 3FE driving the huge XMLs lt1fire currently has on his truck.
How much power does the 3FE have?
Here are the 6.2 specs. Not very impressive. I've driven one in a chevy truck with stock tires. Not very impressive.
- Engine RPO Codes: LH6 ('C' series, with EGR) and LL4 ('J' series)
- Displacement: 6.2L / 379 cu in
- Bore x Stroke: 3.98 × 3.80 in (101 × 97 mm)
- Block / Head: Cast iron / Cast iron
- Aspiration: Natural
- Valvetrain: OHV 2-V
- Compression: 21.5:1
- Injection: Indirect
- Horsepower / Torque (at start): 130 hp (97 kW) @ 3,600 rpm / 240 lb·ft (325 N·m) @ 2,000 rpm
- Horsepower / Torque (at final): 143 hp (107 kW) @ 3,600 rpm / 257 lb·ft (348 N·m) @ 2,000 rpm
- Horsepower / Torque (army): 165 hp (123 kW) @ 3,600 rpm / 330 lb·ft (447 N·m) @ 2,100 rpm
- Max RPMs: 3,600
- Idle RPMs: 650 + or - 25
but there are better and easier options.
With a turbo they'd probably be okay, but there are better and easier options.
Better yes... easier ? How could it get much easier than something so similar to a SBC ?
It will have that great diesel sound.
Not to clog this up with more 6.2 tech but my reasons for doing it are..... the parts are free as they will be coming out of my suburban. I'll be doing the work myself of slave labor of friends
All I have to buy is the adapter.
So cost is down. My mpg will go up and I may actually drive it without having to mortgage the house to pay for the gas.
I can run bio and the WVO that I run in my mercedes diesel.
It's a diesel so it is cool.
I DD a 6.2 suburban that weighs more than my 80 and it has plenty of useable power..... yes I can turbo it at a future date and most likely will.
The lower power will keep wear and tear on my LC parts to a minimum.
I love LS motors and have had many LS powered cars.... few with over 500Hp 1 with over 600 HP but it is not what I want in a 6000k truck.
