Hi guys
I have a piggie with a 2 f engine and a holly carb.
I have set the ignition timing with a light, have set the mixture screws with a vacuum guauge .
On the carb there is a vacuum advance timing port. On the intake manifold there is a vacuum port.
On thevacuum port of the carb carb at idle, no vacuum. Only vacuum when the revs are higher. On the manifold at idle 23 Hg mm of depression. If I plug the hose on the intake manifold it will advance the timing . If I plug it on the carb, no advance port am'I supposed to use.?
When I bought the piggie it was connected to the intake manifold but I moved the distributor for more or less advance to try to get the good timing so I loose al reference.
On a oem carb, at idle, does'the vacuum port for the distributor give vacuum or not aat idle? In other world, is your timing set on 8degrees btdc at idle, connected to your vacuum hose?
Thanks for yours answers
Regards
Regards
