Hi everyone,
I need some help with a recent problem to crop up in my 87 FJ60. A few weeks ago I noticed that the key was hard to turn from the locked to the first position. It almost felt like it was a new key that was not cut perfectly correct. Once the key passed the first position it was fine and the truck started fine and the key returned to the running position perfectly.
Today I had the same issue but I was almost not able to get the key out because the key would not go from the first position to the locked position and allow me to remove the key. I felt as if I might actually snap the key. After playing with it for a bit I was able to get it to return and remove the key.
This is an issue with all the keys (known good keys) so I have ruled out a key issue. Any idea as to what could be going in? The problem seemingly came out of nowhere.
Is a new ignition switch needed? Is it still available? Is it easy to rekey a new switch?
Would some type of lock live help?
Thanks,
Zack
Thanks,
Zack
