I was wondering that too. Maybe no rear sway? Reworked KDSS?What does the '20 HE have or not to score a few more over the '17 LC?
Think HE has different rear spring Rate or something? @bloc can tell you more.I was wondering that too. Maybe no rear sway? Reworked KDSS?
Or it could be just manufacturing variation b/w different unit…..
To be fair the numbers are well within margin of error given how unscientific the RTI test is. As evidence of this, both a base and a HE should be able to use all of their suspension travel (on the bumps on stuffed corners, fully dropped out on other corners) on a ramp, and nothing mechanical changed to increase total travel.What does the '20 HE have or not to score a few more over the '17 LC?
Per the diagrams the spacer comes on US market cruisers, but that is clearly not actually the case. So while we can check diagrams for other markets we’d need to verify with owners in those places to see whether it’s true.Probably just a bit lighter and stiffer rears. They dont have a spacer up front do they?
What even does ship with the factory spacer?
Interestingly the diagrams show it being installed on some ROW AHC equipped 200s, but not all. Again we’d need to verify.
Ohhh well if thats is not an interesting point… since i know you have the bulk of the part numbers down pat, do you know what the corresponding front spring is that an AHC LC would have received along with this mythical spacer?
Im 100% doing this or a 15-20mm, still deciding on UCAs. Probably doing SPC adjustable. But im still lost LOL.
I would say to not bother with UCAs. Not unless you're planning to do a sensor lift over ~2". For a street car that's not lifted over that, IMO, the factory UCA is superior. Race car, there may be advantages to using one with more accurate ball joints and sphericals. Otherwise most UCAs are just to address alignment range so it can be brought back into spec when lifted over 2".
Thanks. I like not spending money too.
The shop recommended it and the alignment went well, but my front left could use a touch more caster and they were maxed out.
I believe i have a driver side spring sagging a bit or maybe im just doing too much when im the only occupant and all the weight is in that corner it does pull to that wheel.
Under hard braking, before and after any mods i did, it was the first corner to break traction and is always the first trigger ABS. I can hear it.
There is always chassis differences as well that could be at play.
Here it is again. Maybe one of the alignment experts can chime in.
Oh I’d still pick the pre-facelift G for sure. Now let’s consider the Defender…. or not.
