- Thread starter
- #61
Micro cracks carb float are fixed. I suspect that I had gas inside the float when soldering causing the brass to bulge and tear in many areas. I dried the float in the sun for a couple of hours allowing fumes to vent out of top hole of float. I was able to identify the small cracks because as I wiped the float in the sun vapor would condense near the cracks. I smeared solder on the 5 locations of the mini cracks. Then re soldiered top hole. Seems to be holding, it is not pretty, and hope the extra solder is not affecting float performance.
Carb is still flooding, needle is not shutting off? I used the Keystone 011-4020A kit to rebuild, but I may go back to original parts that I took out to see I they can be cleaned up. Mine is a June '65 carb. The Keystone kit is Aug '66, so not sure of the differences. Could the fuel pump build too much pressure?
Bowl is draining out overnight/few days. My crankcase if full of gas. The oil in the crankcase is so watery for all the gasoline, that I hear a water noise flowing down over the valves after shut down. I am clueless as to why the bowl drains out. I know the Step-Up Rod in the Keystone kit was not a true step, but more of a step and then a flare back to the overall diameter. I many look at the Toyota Kit 04211-60086 to see if hat has the truly stepped rod. What are possible causes for the drain?
Funny thing is that the fuel flow (flooding) does stop, because the bowl drains. So the needle valve does work.
Anyone out there still offering carb. rebuild services? It does run, I am able to get a low idle...but half choked. Gotta fix the flood and drain.
