New owner of an AU import Troopy HZJ75. Love it!
I’ve got 40s, 80s, and 100s and know their coming issues but not 70s
Questions as I encounter and troubleshoot:
1) fan switch for heat/AC does not turn on fan on setting 1 or 2. Works fine on 3 and 4 speeds. Ideas?
2) insulation padding on floor under left side footwell is soaking wet. Removed AC drain pipe and it is clear. Doesn’t smell like radiator fluid leaking from heater core. No sunroof drains to worry about. Thoughts?
3) glow light on dash doesn’t go off but stays on even when a cold start but outside temp is 60. Should go off after a few seconds. Starts fine and runs great. Thoughts on glow system?
4) the two plugs in pics are not hooked up. They are under left side foot well on left behind the triangular plastic panel. The larger appears to never have been connected. What are these for?
