- Thread starter
- #41
Mick,
I bought a 105 today. Would appreciate it if you can put up pics of the upgrades you have made to your 105.
I would like to do the following:
Tweek up the interior
Put in an intercooler perhaps if its not too much work and has no adverse effect.
Also perhaps change to auto transmission, again that is if it does not cost a ton and has no adverse effect.
Put in power windows, mirrors.. what else?
Regards
Sajid
G'day Sajid
The only mods done to the 105 as yet are the snorkel that was already fitted when I bought it, the bullbar which I will be changing yet, and the dual battery system which hopefully I should finish wiring up tomorrow.
Go for the intercooler if you can. Turbo diesels run "on boost" more often then petrol motors so deserve an intercooler more then petrol motors. They will allow you to squeeze a bit more power out of them without getting them too hot.
Auto transmissions work well with torque curve of the diesels.
The interior upgrades should be easy if you can get hold of a GXL or VX interior to raid the bits from.
Good luck with your build and make sure you post some pics
