The sunroof on my wife’s 97 refused to shut one day after making a funny noise (her words). So, I went search ‘mud for possible causes and solutions. I wasn’t able to find much save for this thread where several people contribute their findings:
https://forum.ih8mud.com/80-series-tech/241694-sunroof-stuck.html
Armed with the knowledge of broken cables I decided to determine if that was indeed my problem. It turns out it was, and after a brief chat with my parts guy I had two new sun roof rails heading my way. About half way through I realized that documenting my trials and tribulations might help some other people avoid some of my mistakes. So, I took some pictures during reassembly.
While you are working in this area you may consider the bicycle tube fix detailed here:
https://forum.ih8mud.com/80-series-tech/235129-bicycle-tube-sunroof-fix-wind-noise-gone.html
Tools you will need:
Various size flat and Phillips blade screwdrivers
8, 10, 12, and 14mm sockets & ratchet
TSRM
Steps:
1)[FONT="] [/FONT]Remove headliner; follow the TSRM’s instructions to disassemble the interior and drop your headliner. I can take some pictures of this process if people wish when I reassemble it. For now I’ll focus on the sun roof itself. This took me a little over an hour.
2)[FONT="] [/FONT]Remove the plastic trim from around the sunroof – be very careful if you have a tan interior as you cannot buy new replacements in tan. Mine were very brittle and shattered. The TSRM calls these pieces “sliding roof garnishes”.
3)[FONT="] [/FONT] Remove the sliding roof glass. This entails removing six 10mm nuts that were uncovered by removing the garnishes. Pay close attention to any shims that may be in place between the bottom of the glass and the top of the rails. These help position the sun roof vertically in the hole. Mine had one on each side of the front studs.
4)[FONT="] [/FONT]The next step in the TSRM is to remove the drip channel. This is attached to the rails and as noted by the TSRM must be pulled forward to remove.
TSRM
Steps:
Re-reading this thread, and in the first post -
It is not necessary to remove all 4 trim pieces. You only need to remove the two side pieces, to access the nuts that hold the glass in place. I left the long front and rear pieces on the glass. Might save someone a few minutes, or the headache of replacing trim.
