How to power aftermarket gauges??
Fj80oregon
GOLD Star
Oregon
95 Fzj80 US spec. Getting my turbo buttoned up and trying to wire my AEM gauges boost, water temp and Air Fuel Ratio. I purchased a blue sea box with 4 outlets. I need a 12v source that’s hot with ign and acc preferably. Not sure how others have done this and would like some input and ideas that have been successful. I have a EWD but wiring is not my strong point. Thanks in advance.
I pulled an ignition switched positive from under either the driver seat or center console. I used that to trigger a relay. The relay has an 8awg power wire from the battery and from the relay to the fuse box. This way you're not overloading your switch source. The wire I used to switch the relay wasn't plugged into anything.
If you are having trouble finding an ignition switched source of power use a test light or voltmeter and probe some empty plugs with power on. If you find a hot wire turn the ignition switch off. If it goes off turn the vehicle on and check for power again and that it doesn't shut off after a short time. White wire and white wire with a black stripe tends to always be ground wiring.
