The motor on my sunroof just stopped working. I don't know what happened. No action from the motor at all. Do you think it wouldbw a faulty motor or jammed up some how?
No you don't. I just had mine out and didn't need to remove the glass. However, I may need to as my sunroof is STILL leaking.
I removed the top corner cover plates that are held on with one phillips head and used sealant underneath but that didn't stop the leak.
I originally removed the whole sunroof assembly to weld up the holes left after removing my stock roof rack. Upon removal of the headliner I noticed water stains on the backside of it & assumed that they were from previous downpours with the drains clogged. Well after unclogging and cleaning the whole assembly and reinstalling, it is leaking from the front corners, adjacent to the triangular backing plates that show corrosion. (see pics below).
Do any of you who have removed this seem to recall a rubber seal or gasket between the track rails and housing body? If so, that may explain my leak.
View attachment 363441View attachment 363442
Currently have cruiser garaged due to rain and same issue. Sucks. Bought a used sunroof unit that is non operable. So now I’m thinking new rails like OP.Having the same general issue where the sunroof won't tilt up or seal in one corner. The rest if the operation is fine. Weighing out buying a used sunroof assembly and risking it breaking just like everyone else. Trying to fabricate a fix for mine. Or buying new rails....
New rails being about $400 for each side...wow. that's a lot to pony up. This is from Norwalk Toyota.
Did I miss something regarding the replacement parts others have mentioned in this post?
@Rkroelin I assume back in 2009 you paid much less for new rails? Haha.
Did you ever figure out a solution to this?Facing the same issue now
forum.ih8mud.com
forum.ih8mud.com
ThanksSure did. tried a used sunroof assembly but it was actually in worse condition than mine. So I ordered new rails from Toyota. They are the complete part with the rail and slide. just pull out the guide chain and unbolt the old rails and bolt in the new rails and shove your original guide chain back in and it is literally as good as new. I am so happy with this repair! It was expensive but i wanted a functioning, non leaking sunroof. I did not want to tape, caulk, or weld mine shut. See this thread for more.
and this one:![]()
How To: Sun Roof Repair
forum.ih8mud.com
Headliner and sunroof pulled to fix leaks if anyone wants pics!
forum.ih8mud.com
here are the part numbers;
63603-60014 guide rail right
63604-60014 guide rail left
Save your money on the glass, unless the gasket is really bad. I did buy new glass because it came with a nice new supple gasket, and it still did not seal. But it doesn't matter, that is why the whole assembly is in a tub. It is like it was designed to leak, that is why there are drain tubes at all 4 corners of the tub. If your drains are clear, you got it made. Maybe check that the sunroof is closing all the way to minimize the water that leaks in. Then since your headliner is out, have a helper dump a glass of water into the corners and watch it drain and look for leaks. I did this and the sunroof pan and drain tubes can handle a substantial amount of water, more than will ever get in from a rain. You can also close the roof and have same helper aim hose up to rain down on roof and you can shine a light in the corners to see which corners are leaking most and adjust the sunroof position with the 6 bolts it is held to the rails with. Then secure with blue locktite. Because mine did work themselves loose. I did this as best i could and with the hose, a few drips drip in at each corner. But i am not worried about it at all because i know the drain tubes can handle it.Thanksglad it worked out. My last ditch effort for my leaking sunroof is to try the bicycle tube fix before spending 500 on new glass with seal...my headliner is out, drains clear, everything hooked up...but the gasket around the glass has shrunk over time..
Yeah I dumped 4 gallons over it and I watched it all drip out onto the ground through the tubes. It didnt get wet inside during rain however every time I take it through a car wash (my local one has a tunnel the car goes through) after that then it's wet... Strange that the car wash has so much volume of water it can't handle it..Save your money on the glass, unless the gasket is really bad. I did buy new glass because it came with a nice new supple gasket, and it still did not seal. But it doesn't matter, that is why the whole assembly is in a tub. It is like it was designed to leak, that is why there are drain tubes at all 4 corners of the tub. If your drains are clear, you got it made. Maybe check that the sunroof is closing all the way to minimize the water that leaks in. Then since your headliner is out, have a helper dump a glass of water into the corners and watch it drain and look for leaks. I did this and the sunroof pan and drain tubes can handle a substantial amount of water, more than will ever get in from a rain. You can also close the roof and have same helper aim hose up to rain down on roof and you can shine a light in the corners to see which corners are leaking most and adjust the sunroof position with the 6 bolts it is held to the rails with. Then secure with blue locktite. Because mine did work themselves loose. I did this as best i could and with the hose, a few drips drip in at each corner. But i am not worried about it at all because i know the drain tubes can handle it.
That makes sense, I haven't had water come in during hand washes either...I did re-shim the glass. But you're right it could be from the force of the water / air pushing the glass in.IME some car washes have so much downward pressure on the roof they can push the sunroof glass down, increasing the size of the leak. The sunroof on my
96 model never leaks into the cabin from rain or washing by hand, that is until I took it to one of the newer carwashes in town. It was very apparent that there was a ton of force blasting down on the roof as I went though the wash cycle which was followed immediately by a shower of water coming down into my lap and onto my head from above. I quickly opened the sunroof door then pushed up on the sunroof glass to help slow down the flood. May also be time to reshim
the glass. FWIW.
Hey man im hoping you or soomeone can help me out on this. Just got a 91 and the sunroof does not leak. Tilt up and down is perfect. Slide function was kinda "stuck" on the right side. I hit it with some lube and it opened (waaalaaaa), however the right side still seems to be kinda off the track. It will close ok but when sliding open the right side gets kinda off center and stuck unless i assist it with my hand. Does this make any sense to you? Im afriad to mess with it to much because i dont want a leak, but its so close to working properly I really want to fix it. Seems maybe I just need to reattach the right side? Im kinda afraid to pull the headliner and all that and mess it up but maybe its not to bad? I was thinkiing of a glass shop repair till i found this thread, now im thinking maybe i should give it a go. TIASure did. tried a used sunroof assembly but it was actually in worse condition than mine. So I ordered new rails from Toyota. They are the complete part with the rail and slide. just pull out the guide chain and unbolt the old rails and bolt in the new rails and shove your original guide chain back in and it is literally as good as new. I am so happy with this repair! It was expensive but i wanted a functioning, non leaking sunroof. I did not want to tape, caulk, or weld mine shut. See this thread for more.
and this one:![]()
forum.ih8mud.com
forum.ih8mud.com
Sounds like it’s has not been used much by the PO. Best case scenario just lube it and cycle it open and closed while assisting with your hand a few time and see if it gets better.Hey man im hoping you or soomeone can help me out on this. Just got a 91 and the sunroof does not leak. Tilt up and down is perfect. Slide function was kinda "stuck" on the right side. I hit it with some lube and it opened (waaalaaaa), however the right side still seems to be kinda off the track. It will close ok but when sliding open the right side gets kinda off center and stuck unless i assist it with my hand. Does this make any sense to you? Im afriad to mess with it to much because i dont want a leak, but its so close to working properly I really want to fix it. Seems maybe I just need to reattach the right side? Im kinda afraid to pull the headliner and all that and mess it up but maybe its not to bad? I was thinkiing of a glass shop repair till i found this thread, now im thinking maybe i should give it a go. TIA
Oh man that would be sweet thanks for the reply. What is the recommended lube? I used wd40 to get it that first time because thats all i had.Sounds like it’s has not been used much by the PO. Best case scenario just lube it and cycle it open and closed while assisting with your hand a few time and see if it gets better.
Then post back
