How to remove bellhousing with siezed crank?
SW Washington, USA
Website
instagram.com
Hello. I'm stuck. So, crankshaft siezed, and I got my motor out but can't get it on a stand. (73 1F)
The flywheel needs to come off in order to pull the bell housing off, but I cannot turn the flywheel to loosen all the bolts.
Anybody run into this issue? Got any tips? Much appreciated :)
Huh? All the bolts are accessible for flywheel when the bellhousing is in place. Just put a ratchet or breaker and crack them loose. Remove the flywheel cover if you haven’t?
Or do you mean the 6 -
10/12mm bolts for the clutch cover aren’t accessible? That would make more sense. If so, do what @rkymtnflyfisher said.
Yes that's what I meant
