Phil's method will not work, as long as Toyota's design holds up. Between the grease in the photo and the needle bearing is both an oil seal and a tight brass bushing.
Can't see how Slee's method works either, unless there is a needle which squirts the grease onto the bearing. I mean: If you press grease in from the flange side, how will it be pushed in to the bearing when there is an oil seal at the back, preventing air or old grease from eascaping? Or does the grease just re-distribute itself during driving?
Edit (mistaken):
The oil seal is actually on the thicker part of the CV assembly; so that when the CV is pushed away from the spindle, the seal is not in the way for greasing.
See more below.
Edit (mistaken):
See more below.
