Akella
Here is prices for installation parts as a lot of you guys requested. This is only oem parts.
REAR LOCKED
GASKET, REAR DIFFERENTIAL CARRIER, W(*DL) 42181-60070 1 $4.29
BEARING, TAPERED ROLLER (FOR REAR DRIVE PINION REAR) 90366-40059 1 $59.16
BEARING, TAPERED ROLLER (FOR REAR DRIVE PINION FRONT) 90366-30038 1 $38.52
BEARING(FOR REAR DIFFERENTIAL CASE), W(DIFFERENTIAL LOCK) 90366-60002 2 $122.20
11 SHIMS 11 $24.44
Total: $248.62
REAR UNLOCKED
GASKET, REAR DIFFERENTIAL CARRIER 42181-60060 1 $4.29
BEARING(FOR REAR DIFFERENTIAL CASE) 90368-50024 2 $76.79
11 SHIMS 11 $24.44
Total: $203.20
FRONT LOCKED
GASKET, FRONT AXLE DIFFERENTIAL CARRIER, W(*DL) 42181-60080 1 $3.84
BEARING, TAPERED ROLLER (FOR FRONT DRIVE PINION FRONT) 90366-35028 1 $61.89
BEARING, TAPERED ROLLER (FOR FRONT DRIVE PINION REAR) 90366-30067 1 $36.58
BEARING(FOR FRONT DIFFERENTIAL CASE), W(*FDL),LH 90366-50007 1 $34.06
BEARING(FOR FRONT DIFFERENTIAL CASE), W(*FDL),RH 90366-75001 1 $24.66
22 SHIMS 22 $43.34
Total: $204.37
FRONT UNLOCKED
GASKET, FRONT AXLE DIFFERENTIAL CARRIER 42181-60090 1 $3.84
BEARING(FOR FRONT DIFFERENTIAL CASE) 90366-50007 2 $68.11
22 SHIMS 22 $43.34
Total: $213.77
Not all bearing needs to be changed. Do some research and decide what you want to do.
Read Zuk's write ups as he does amazing job on gear installs
Also you can source Aftermaket install kits from a lot of vendors like Cruiser Outfitters and Justdifferentials and etc. Just an option to save few $$
REAR LOCKED
11 SHIMS 11 $24.44
Total: $248.62
REAR UNLOCKED
11 SHIMS 11 $24.44
Total: $203.20
FRONT LOCKED
22 SHIMS 22 $43.34
Total: $204.37
FRONT UNLOCKED
22 SHIMS 22 $43.34
Total: $213.77
.Also you can source Aftermaket install kits from a lot of vendors like Cruiser Outfitters and Justdifferentials and etc. Just an option to save few $$
