How to Disable the Fan Behind the Clock (95-97 Dash)
I have always disliked the constant drone of that little fan behind the dash. Today I decided to finally disable it. Other Mudders have posted that the fan sits below the digital clock in the top center of the dash. I would say it's more like directly behind the clock, and easier to get to by removing the center top dash vent and clock unit itself (rather than through radio removal). I also couldn't find the fan or figure out how to disable it by going through the radio access.
To pull out the center top dash vent/clock piece, work a plastic trim remover around the edges and just pull gently. There are two friction clips on either end of the piece (right and left sides), so try to pull on those sides rather than in the center of the piece. As it starts to come out, you'll see that there are some sharp ridges on top of the piece that is coming out. Try to finesse/softly push up with your fingertips the soft dash where it meets that top of the plastic piece you are removing, so as not to damage the dash. Disconnect the clock wire by pushing down on the top center of the wiring plug as you remove the assembly from the dash, it's an easy connector.
Once you have the center vent/clock assembly out, you'll see the fan sits horizontally right behind the clock. Just disconnect the little white electrical connection to the left of the fan. It's useful to have the keys in the ignition while you do this, to help you see/hear the fan to identify it, and to confirm that you have disconnected the fan.
It's a little unnerving to pull apart dash friction fittings, at least for me. Just try to take your time and pull the vent/clock out gently and straight. It should come out with a little gentle persuasion. It's also a good time to use a paintbrush and a wet detail cloth to clean up the trail dust in all the nooks and crannies.
I was installing the JDM red hazard switch (84332-26080, I realize the triangle is in the wrong orientation, I'm okay with that), and taking out the inoperable CB which was below my radio. So, I tried both the radio access and removal of center vent/clock assembly. If you are just looking to disable the fan, I suggest trying the vent/clock assembly first. You might be able to get it done in 15 minutes. The radio removal is more involved. YMMV.
I have never noticed a fan there... are you sure its not cooling the Government installed tracking chip?
Be careful the Black Helicopters could be after you.🤣
Seriously, what's the fan cooling? Why is it there?
I'm definitely on the lookout for the black helicopters, and I'm sure there's a chip planted somewhere. I just hope that chip helps me track down my rig if some dirtbag steals it. o_O
I'm guessing the Toyota engineers felt the stock double DIN radio needed some external cooling air flow. The fan blows down toward the radio. But I have been on the trail looking over maps irritated by that little whir far too many times. It even runs even with the engine off if the key is in the On position.
I also disabled that buzzing noise that comes from the left kick panel when you turn on the ignition, too. I just like silence, especially when I'm in the outdoors, sitting in my truck checking out a map, a cool view, a coyote, etc.
I don't want to hijack the thread, so you might want to spell it out in another thread, but @
bicycleagent003, how do you disable the buzzing from the left kick panel?
Looks like a fairly standard CPU fan in which I'm sure you can easily find a suitable replacement that'll operate very quietly or rip it out?
That fan was indeed to cool the radio setup. It wasn't fitted on base models, just higher trim levels with the higher end radio. My 1996 HZJ80 didn't come with one. Just rip it all out and put in a semi-modern head unit.
Ah that's why I have never heard it, the LX doesn't have one.
It gets very hot under there if you are using the system in a hot climate so guess it's just to circulate the air under there. On mine I have never noticed any noise, I presently have the dashboard out and it does work but very very quiet.
Regards
Dave
Mine is quiet. Didn't know it was there until I was removing the clock to install a tablet mount.
I don't have one and after reading what the OP did, I felt cheated. Reading further down I realized, that's what I get for not buying a higher level Cruiser. I went from feeling cheated to feeling cheap.
To disable that buzzing noise when you first put the key in the ignition, just remove the left side kick panel. You'll need a 10mm socket to get the foot rest off, then I think you might need to remove the threshold plastic piece that you step over upon entering the DS, then remove the kick panel itself. They all fit together in a certain order which is obvious when you're looking at it, but my rig is not right in front of me as I write this. Once you get all those wires down there exposed (and there are a lot of them), just put the key in the ignition and take it out a few times while you have your head stuffed down there in the DS foot space. I seem to recall it was something a little larger than the EFI relay, and also cylindrical, and that I just pulled it out and Poof! no more buzzing noise. It was years ago that I pulled it out, so I can't recall any more details than that. But it was worthwhile, and easy.
If you're going to pull some wire through the firewall, it's a good time to do that, and the Pin-7 mod (Center Differential Lock Pin 7 Mod - Slee Off Road - https://sleeoffroad.com/center-differential-lock-pin-7-mod/), and to install some OEM toggle switches in the blanks to the left of the steering wheel. All that stuff is right there.
Post up how it works out for you. Happy trails.
Thanks for the details, maybe someone here knows what that clicking part is supposed to do.
Can I see pictures of how you mounted your tablet here?
Never paid much attention to this or heard it running. Is it thermostatically controlled?
The chips in the cell phone, not the car
My 1994 radio cooling fan is making that annoying whiney noise and I'm replacing it. It may be out there, but I couldn't find a thread with details on access, so here it is.
For anyone just trying to disable the fan, you'll need to remove the trim that includes the radio bezel, plus the trim right above that with the double register vents. Once you do that, you can pull a small connector on the front of the fan assembly and the fan will stop. The best look I got for the fan bracket is from a parts diagram here, looking into the center dash:
For anyone who wants to replace the fan, you'll need to remove the first piece of HDPE duct work behind where the center double register vents go. Mine just slid right out. Once you have that out you can access two 10mm bolts, one on each side and then wiggle and twist the fan bracket out:
The fan is a completely typical Panaflow 92mm 2-pin, so there are many options around $20. I'm using the Noctua NF-A9 Flex 12v 3 pin because of durability and quiet operation, and I'll leave the 3rd pin, the tach pulse, disconnected.
The circuit diagram gives the polarity of the connector, and you gain access by removing the screws on the small black connector housing, swapping in the new fan by soldering +12 to pin 4 and ground to pin 1. The small circuit board in there has an 11ohm resistor and a diode in the path, so on the original fan it dropped voltage by about 1.9 volts (1.2 + .7). The new fan uses 1/3 the amps of the old, so I'll get a drop of about 1.1v ( .4v _+ .7), so it will run at about 13v when the engine is running. Depending on the fan, you may need to add resistance or other control to get the fan speed you want. There's also a choke across the inputs to keep noise from impacting the radio.
from the EWD:
i'm amazed at how my fan is still so quiet, but when it goes, it's getting disconnected.
