Apologies if this has been posted before, but this looks pretty helpful and easy. Can you buy just the original/OEM CDL switch?
Tank, from Toyota or somewhere else?
Right, that is what the guy used in the video. I'm wondering where I buy the CDL switch from?
I am trying to source a female connector the CDL switch plugs into.There is no new news, only a new audience. I did this mod over 20 years ago.![]()
I've backed up a few feet and then pulled forward to the starting point, but haven't driven around.It could be a bad low 4 position switch, a bad difflock indicator switch, a bad difflock control module, a wiring issue or a bad actuator.
Have you moved the vehicle when attempting to lock it or are you stationary?
I've documented it has a locking center diff, but it currently relies only on automatically locking the CDL when entering low range. It does not yet have a selectable CDL switch which would allow locking the center diff while still in high range. To the best of my knowledge and research, ALL 80 series have CDL functionality and at a minimum will lock the center diff when entering low range. Some model years included additional functionality (which this thread is addressing) of a CDL switch which would also allow you to lock the center diff in high range.You need to ensure your 80 has a transfer case with a CDL - hf1a (as fitted to my 80) does not and is for factory part-time 80's - not sure if hf2a all do as I don't fully understand if all full-time 4wd 80's got a t-case with the extra 'stuff' (CDL, viscious coupling section, etc.) and if the CDL is electrically selectable or not.
With the truck off and in park turn the key to the ignition and have someone cycle the low range lever or press the CDL button while you lay under the car and listen for the actuator to cycle. If you aren't hearing anything then try driving far enough to get things warmed up and then repeat the process for listening for the actuator. I've also had the issue of the CDL not wanting to cycle when its cold.I've documented it has a locking center diff, but it currently relies only on automatically locking the CDL when entering low range. It does not yet have a selectable CDL switch which would allow locking the center diff while still in high range. To the best of my knowledge and research, ALL 80 series have CDL functionality and at a minimum will lock the center diff when entering low range. Some model years included additional functionality (which this thread is addressing) of a CDL switch which would also allow you to lock the center diff in high range.
