Here:
Hulsty's buddy running his 75 daily driven ute.
14lbs boost, gt2876, w2a ic, 12mm pump from a 1hd-ft dyno'd awhile back at 118rwkw.
Safe pre turbo max pyro temps.
Hes putting 20lbs into it at the moment with no issues that I have heard of...
20psi with a decent intercooler on a 1HD-T would net you around 200kw at the crank at 3,600rpm.
I'm using 80% VE, 260 g/kwh, 17:1 A/F ratio, 70% comp, 60% intercooling to get those figures.
Fuel is ~95 cc/1000 shots.
My 4BD1T with 20psi from a tiny T25 and no intercooler isn't far off 200hp (crank).
I tried to get a photo of the boost gauge at 24psi and the EGT gauge at 750C, but couldn't hold the camera steady enough.
Did you know, the stock 1HZ injection volumes are within a few percent of the stock 1HD-T injection volumes?
On the same fuel loading, the 1HD-T produces 380Nm and 125kw. The 1HZ produces 285Nm and 96kw.
That is the difference in efficiency relating straight to power and torque.
Graeme should be able to tell us what a stock 1HD-FTE puts to the wheels. It's likely around 118kw on about 12psi boost with a tiny intercooler (about A4 paper size).
BTW, the figures on that dyno plot don't add up.
Power = force x velocity, but if you multiply out the tractive effort and velocity on their charts you get 387kw. I'd like to believe the 147hp figure and the curves, but none of the other numbers are true.
Post turbo EGT's are useless.
Crushers sold his old 75 to a guy running 14lbs boost, propane injection, intercooled and its still ticking apparently.
Crushers has been quoted saying max boost breaks engines. Does that mean he never drove that one at 14psi?
