For those with aftemarket E-Lockers, it seems like they unlock / lock when you reverse tire directions.. roll back ,etc. but in real world experience, is that really even an issue? or no biggie? I still keep going back and forth on E vs Air...
Thx in advance!~
I really haven't noticed that issue. Note that I don't rock back and forth maybe as someone stuck in a big snowdrift. Engaging the e Locker is more proactive than reactive. I learned when I'm going into a sticky situation where I need it. I just stop or slow down and let it engage and roll through it. Sometimes, I might be climbing a mountain where the locked rear diffs are not enough. Then I just turn on the e Locker and move on through it. I turn it off as soon as I'm past the problem area. A few times if I'm moving really slow, I will engage it while I'm rolling and then it takes over. That really comes from understanding how the engagement mechanism works internally and learning the touch for engagement when moving very slow.
One of the most dangerous cases where it bailed me out was in reverse. I had pulled down into an area (tight hole) where both rear wheels were elevated, spinning and making little contact with the snow-covered ground. One of the front wheels was also spinning. Engaging the e Locker let the front wheels do the work to back out.
I like how it works underwater. I usually turn it on as I'm making deep water or mud crossings because I can't see what I'm driving over and the added stability that it provides. Being submerged in 2 to 3 feet of water or mud is not the place where you figure out that you need the front to be locked. I don't have ATRAC, so I lean on it for stability more than someone with ATRAC.
One of the main reasons I went with the e Locker is the ease of installation after it had been built by gearinstalls.com. I'm somewhat in the middle of nowhere and didn't know of a local place to go for help or installation at the time I was ready to install.
I'm a long way from Arizona, Colorado, California, Oregon, or North Carolina. where it's easy to find builders and installers. It was a DIY job that needed to go perfectly out of the box. If it didn't go well, I would be up a creek and I knew it.
The rear LSD still works very well. As long as it still works, I love it. I'm starting to appreciate it more as time goes by. I don't need to think about turning it on. It works when I need it.
