Cost aside anyone can wheel with 37's.
35's keep it challenging but always get you there
I've wheeled 35's. Hard. They were good.
I wheel 37's now. They are better. I run the same trails and they aren't as 'hard'.
Brother Rob will eventually get 37's, and then he will sing their praises. Trust me, I know him.
I will never put 35's on my truck again, unless 37's suddenly got 3-4 times as expensive as 35's.
I also happen to be running stock gears at the moment. I've never stalled the truck, it's always had enough power to get over whatever ledge I think the truck is capable of getting its belly over. I do have 5.29's waiting on a shelf, and am anxious to get them in. Not a deal breaker though.
That's what I said. Then Tools (coughyourbrothercough) found me a deal, ~$850 for a set of 4.
Too bad you still had like-new 35's on your truck that month.![]()
Cost wise, you are correct. Otherwise,![]()
To each his own. I think 37s on no or limited lift look kinda rediculous but for yOHda it works just how he likes it and thats what matters. time to make your own decision.
Good luck, its all about the backspacing to get it right.
Some of u guys are getting a little carried away with bumpstopping all ur up travel away just to run a bigger tire and little to no lift...
Sounds like where 37s really shine is on all out rock crawling type stuff. Since I'm going the expedition style route with my 80, 35s sound like they should be fine. As long as I can make it through Canyonlands...![]()
