ARCHIVE How i approached Rebuilding Restoring & Refreshing the HJ61 NON-USA Full Floating rear axel in my 10/88 FJ62LG-PNEK w/ a MTM conversion
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
10/88 FJ62LG-PNEK w/ a MTM conversion ....
i will be documenting the Step by Steps outlined in the various OEM FSM's and applying any Tecqniques i need to to produce both a properly functioning end product as well as a NUTS and BOLTS all cosmetic restoration & re-fresh
- ALL Needed Japan. Spec. OEM parts maker power train and chassis parts for this necessary project job scope minus the ones from @cruisermatt , sourced via @cruiseroutfit / Cruiser Teq | Land Cruiser Specialists Powered by Cruiser Outfitters - https://cruiserteq.com/ and why i choose them for this unique overall job scope of events .....
- factory TOYOTA HJ61 NON-USA factory Limited Slip option Differential hand assembled with all new parts to my Spec's by Cruiser matt's OFF road Power Train & Chassis Specialty shop in Winter Part Florida will also be installed by the book FSM style and is a primary focus point of this TECH thread also .....
@cruisermatt
- the Rear propeller shaft will also get repaired by a 3rd party Drive Shaft Specialty Shop / A-1 Drive Shaft in Baltimore Maryland
- i have never come into contact or repaired in any way a TOYOTA Full Floating AXLE , i have been planning this since shortly after late July 2022 when i purchased My Girl the GHOST
- i want to both learn hands on the TECH on this process and incorporate my unique approach to how i will do just that ...
- stay tuned for some good solid FULL FLOATING AXLE TEq TECH ...... :)
matt
USER]
@Von Hayek
Glad those shoes didn’t fail any further.
That’s a sweet hilux ya’ got there…
my 2 stand alone TECH videos below explain in detail the WHY411 on that topic
, YES ,
SUPER HILUX is my boy , he can do what NO 100 Series can touch and no silly 1st GEN. TUNDRA can to my knowledge either
see below , photo's or it does NOT exist TECH VIDEO also ...
Removal of the carrier assy itself required a bit of thinking outside the TEq box
But SAFTEY is job one so we lowered it on 6x6 Timbers
And decided to count to 3 and both use Bryant screw drivers and in tandem pop it off and into the Cradle for SATIN I had whipped up to catch the mess and capture the beast without crushing our skulls
Like Rick and Darrel do on the walking dead …
we used the floor jack then to push up break the seal so all the gear oil remaining after draining the DIFF could escape into SATINS cradle and not rill down my underarms
It worked well …
Your ingenuity is TEq level. All you need is a paint marker. Scribble TEq on those Timbers and that bubble wrap and it’s all OEM SST.
you aint seen nothing yet ,
this very science based tech tread FULL floating axle is about to get a whole lot more diverse and well .........
as OEM as it gets is a Understatement
@cruisermatt 's OFF Road has been involved here , and i plan to tell is like it is on that topic ,
something new and wiked this way comes for sure , all things GHOST
, YES ,
What's a Yamaha version???
Not only are your trucks rad… so is your music selection. You’ve always got the best songs playing, man! I’m sure your shop is a blast!
i have always been motivated and inspired by special people saying special things as they operate special equipment ...
