How far can an 80 lean before tipping over?
Seattle, Washington
Transversing an incline can be a scary experience...even though the degree of the incline can be fairly minimal. In general, how far (or how many degrees) can an 80 with a 2.5" lift with 285s safely lean before tipping over? I'm sure it's probably a lot more than what it feels when your a passanger or behind the wheel. Do those tilt meters work?
Dunno, ask Wench. :D
-B-
Too many variables for one easy answer. On a perfectly consistent surface you could traverse a pretty steep angle. But if your downhill front tire falls into a rut or hole or loses a bead it will shift your center of gravity and you could go over. Lots of help, I know, but there is no simple answer to that question. Most drivers' "sphincter-o-meter" will peg out before they roll due to sidehill angle. Most but not all, hehe. :o
there were some threads with a bunch of numbers.
somehow 45deg comes to mind.
driver tolerance definitely depends on whether the downhill side is the driver or passenger side :D
weight distribution in the truck, suspension and tire size all play a part and will vary between trucks.
The best thing is to test yours by laying out a number of used mattresses on one side of the truck, and setting up an adjustable ramp on the other side. Please post up your results as a data point :D
Much farther than anybody needing to ask this question will ever be comfortable with.
this is the same as the ski slope factor: it looks vertical when it's about 30 deg... :)
My tilt meter only goes as far as 35 degrees and I bet that's not very accurate. I don't think you'll be paying much attention to a meter if you're anywhere near rolling, just remember to keep your hands on the wheel when you go over, saw a chap instinctively put his hand out the window to steady himself once, didn't do his arm much good.
What's the angle on this? I can't work it out, there was no flat horizon to lign the camera up with but if you rotate so the trees are upright you'll see why the angle felt just a bit tippy, I think you're getting into the trouble zone over 35 degrees. The LR fell over later on.
I have a 5" lift and 36" tyres if that helps.
Jon.
Jon.
Got any pics of THAT?
No, it wasn't very dramatic because he didn't have far to tip onto the oposite bank.
FZJFillmore said:
Makes my butt grip my office chair just looking at it.
EDIT - Reworked it, noticed your bull bar for a better angled line to follow, still don't like it.
that's over 45 deg!
Nice edit. I don't think it was quite that bad though, I think those big trees on the right have a kink part way up so the main part of the trunk does grow out at an angle and then streighten up a bit.
That track goes up a steep hill but cuts across the side of it a bit so it's really hard to get a fix on what's vertical, makes it hard to judge by eye so we had to rely on the butt'ometer.
I liked the picture because it's a bit of a conundrum :eek:
