I had a career in rubber materials technology. One negative factor with rubber is that when used in compression, all types have some degree of permanent compression set. That is when rubber is compressed and held in that condition for extended periods of time then the compression load is removed the rubber object will not return to its original dimension. Generally, the hotter the environment, and the higher the amount of compression, the higher the permanent compression set will be.
The standardized material test for this parameter is ASTM D395. An good explanation of compression set is here
Investigating the compression set of rubber compounds
The amount of compression set specific rubber compounds varies widely. It can range from 10% to 40%. Compression set is particularly important in sealing applications. The sealing force exerted by the rubber is a function of how much that piece of rubber has been "squeezed" and permanent set reduces that number.
There are big differences in the quality of rubber compounds used by various suppliers. On top of that add big differences in how parts are made with those compounds. Differences that can make compression set even worse. The lesson here is to buy high quality, name brand rubber components.
After that long winded background info back to the OP's question: In theory, a constant load hose clamp would counteract the effect of compression set.
However: (1) The two wire Toyota clamps are known to work great. Compared to conventional worn screw clamps they provide higher unit loading (more sealing force) under the wires as opposed to spreading the load over a 10mm wide band. (2) If it's a low quality hose the type of clamp and amount of torque put on it may not matter. (3) If the mating metal parts are corroded and rough then hose quality and clamp design may not matter.
Another thing - when a hose if leaking take a close look to determine if the leak path is (1) Between the hose ID and mating metal part OD, or (2) Coming thru the hose itself. If the hose liner is cracked or split the fluid can get into the hose and follow the reinforcing fabric to the end of the hose.
In case you're wondering, yes I do miss my job.
