Home Made Tools
Craftsman makes a tool that is perfect for removing hoses... $2.47 each, not worth making your own.
That is a window/windshield, installation tool
Sears.com
spin_prod_1066498212
Mocked up another inflator
With the valve closed, left gauge reads tire pressure and right gauge reads source pressure
Open it up and they equalize
And the larger screw on chuck is easier on the fingertips than the dually extensions on my old setup :cool:
Leak free and painless compared to inflators with clip on leads and momentary valves
My home made wheel bearing puller for my 40, the key is fed through the bearing and when pulled back lays flat against the inside of the bearing, slide the long tube back and you have a slide hammer type action, works like a charm.
Press brake made from a HF shop press.
Have bent up to 3/8" plate with it.
IRiskWhjUVkm6Et_xV7Gd0-rxAS_jdIPpAKYBNhBuajW7ZPQqCXCE5nYz_HNlzoaxj2fzgGPdDX-BHthdOqzFsb_xQxLnuvr4ovC5LAjN4q5ubkYZ7mICWDvutdWet6iC9wKtmptue1mV6MpTaJnJvHJwyaAVa08gL4qeait5QadQNltfe-3jLoHfvN8ohTvm1e_imWaLfDE3xj772DihQwuiY4GqcIsKvUfiuufeK0SYwvMms8hErlFCsOA-tNDmnuHxQuTjnIMxrifTNQPohe9fRMBeJITweSt0owvLkcyIEad2XcwJ4SOvU17e_CAUXn6EuVG1AcrAAE1kYJtNkdHM8_29dE4HI8NA9pwqVzXG0nnxPzKzxqOhmxAxt02m1DHSk72rmDZoazMANCLw4tGu5bbgYaxZ_-LzGSwo9j0RQnsTKjTveYFcfvxGIQ890VW1BuQRnyPgcDkiV8hQ1YH99cFS9Afa9OV6hdnwgEJSnV1-OI8472lLsk0LKz9q2HCuxO29dIsQhOpV6zGDNAHBw6zq9fy28YYdXvtVVe2YB-JEM3BWHKvaj3KVcCP1PnmbfLPAEFgzB0E23AR6Fp7xXgQuLjogQeUu6KH6qBRoboS=w666-h1182-no
Can i share my diagnosis tool in here??? foxwell nt510 is very eazy to use and powrful ,best tool at home
Care to elaborate? Pics?
Nice tool, great idea, but there's an easier way. Remove the spindle nuts, remove the outer bearing, leave the rotor on, and reinstall 1 spindle nut, then grab the rotor at 3 and 9 o'clock and slide the rotor off with some force. You'll end up with the rotor in you're hands and the inner bearing and seal will be on the spindle.
Before my dad passed away 2 years ago, he was having to change IV bags at home. He had trouble with the push to connect fittings so I made him a tool from a pair of channel locks that would let him squeeze the plastic fittings together without breaking them. It worked like a charm.
Umm... Pretty sure he's talking about the rear axle, not the front.
One piece transfer case puller from scrap.
Thanks jb
. This makes mine the welfare version I drilled a hole in a stock t case cover welded a nut to it and a piece of all thread with a nut welded to it works great
SMG, they (the green ones) used to come with a table like that. It mounted directly on the blade guide. And I've seen one guide broken because of it.
on a HF tool? NO WAY!
  • Like
Reactions: SMG
