Matt.McInnes
Spent the evening calculating Turbo outlet temps for the Garrett GT3082R @ 70F/21C ambient and from what I can work out at 9psi the outlet temp should be around 180F/82C at 15psi the outlet temp rises to 227F/108C.
Excellent to hear.
Most importantly, everything went smoothly. How nervous were you beforehand?
155kw at 5000rpm is 296Nm. But that's engine torque translated to the wheels, if you've got 35% driveline loss (that figure plucked from thin air) then you'll have 455Nm at the crank.
Some dynos are smart enough to calculate a driveline loss from coast-down. Others just throw in a rough figure. RWKW is what really matters, you've got plenty and possibly room for more.
Excellent to hear.
I have a little more than your gestimate
642Nm @ the Rear Wheels![]()
.........I'd really like to see is the same vehicle done on a roller dyno and then a hub dyno to see what difference the tyres make.
Why? What purpose would that serve?
Rick
Please excuse my behind the timeness.... but I see dyno printouts these days (and for some time) show kph (mph) readings in stead of the old fashioned rpms along the bottom. Does anybody know why this has changed... or why they don't show both readings (rpm and speed) along the bottom?Good work Matt... and as an old engineering boss of mine used to say "in god we trust... all others bring data..."
RPM and km/h are interchangable if you know all the gear ratios in-between. I suspect most dyno operators don't so that's the default.
The only vehicles I've seen dyno'd live were on hub-packs. They stuck a clamp lead on a spark plug and run the engine at 3000rpm to calibrate the dyno. Once they know the overall drive ratio it's run and plotted with wkw vs rpm.
The other advantage of hub dynos is no slippage. With a rubber wheel on rollers the actual rolling radius isn't quite your wheel radius.
